928 Forum 1978-1995
Sponsored by: 928 Specialists
First 928 facial
Old 02-29-2008, 10:36 AM
Stromius
Stromius's Avatar
Default First 928 facial
Ah yeah....hi my name is Stefan, I own a 88 928 and I have a problem.
The other night I noticed an ever so slight bit of steam coming from the passenger headlight area. About every 3-4 weeks I need to add some water/coolant as my coolant warning light comes on. My reservoir has a small fatigue crack near the cap so I suspect I'll be ordering one soon.
I wanted to check the hoses in the area of steam so i closely examined the hoses and clamps to make sure there wasn't another concern/project.
I ran my fingers over all the hoses and clamps (wait for it) especially the overlfow hose from the reservoir to the top radiator nipple. I checked the nipple closely, wiggled it and BAM facial of green! I guess blau strudel couldn't hold out any longer. Funny but lesson learned is not to get too close I guess. The breather snapped mid thread.
Part in question is Breather Adaptor (aka Top Radiator Nipple) pn# 928.106.443.02. Is this something the local Porsche dealer would stock?
Also curious if the pressure switch on that same line can malfunction (pn#928.641.513.00)?
Old 02-29-2008, 11:51 AM
morganabowen
morganabowen's Avatar
714-632-9288 928International will have it to you faster then if you drove to your local Porsche Dealer. You will also probably save $$$
Old 02-29-2008, 11:58 AM
dr bob
Chronic Tool Dropper
dr bob's Avatar
And yes, that pressure switch should be on your shopping list too along with the hose. The pressure switch housing gets tired over time and will eventually fatigue fracture. Just another place for coolant to leak when it lets go. On the hose: I've been using regular 8mm (5/16") hose on that for a bit and it's OK, but the bend at the fitting isn't pre-formed so it isn't quite as pretty. The original one has 928 part numbers on it. That improves cooling efficiency almost .000003%, and worth it for the original look.
Old 02-29-2008, 12:19 PM
Mike Frye
Craic Head
Mike Frye's Avatar
When I saw the thread title I thought, "He couldn't mean what I think he means by that."
You did.
Sorry to hear that, I hope it didn't burn too much. It didn't get in your mouth did it?
Old 02-29-2008, 12:28 PM
Ketchmi
Ketchmi's Avatar
A green pearl necklace? lol!!!!!!
Old 02-29-2008, 12:44 PM
Stromius
Stromius's Avatar
yeah...taste not so good. Therapy required. Luckily the engine had cooled for an hour so only warm. Thanks for the advise on the hose...good idea to replace the whole thing. I'll get with the good folks down in Dallas so I can drive this weekend.
BTW Porsche dealer here locally (Barrier) doesn't have it, stock it, support it....no surprise I guess.
Old 02-29-2008, 12:56 PM
ROG100
Basic Sponsor
ROG100's Avatar
Hi Stefan,
The nipple is $2.99 and the switch is $75.95
Hows the front spoiler looking?
Roger
Old 02-29-2008, 01:21 PM
PorKen
Inventor
PorKen's Avatar
I did the same thing recently (but I was too embarrassed to tell anyone).
I didn't think to take off the overflow cap before removing the hose to install this cover, and got a big load in my eye, and hair.
At least it could have taken me to dinner beforehand.
Old 02-29-2008, 01:24 PM
Mike Frye
Craic Head
Mike Frye's Avatar
So you said this was your FIRST facial. Are you planning a second date? Maybe this time with video?
Old 02-29-2008, 02:28 PM
Ninespub
Ninespub's Avatar
That really sucks......I hope you didn't swallow
Paul Barrera '91S4
Old 02-29-2008, 02:47 PM
ROG100
Basic Sponsor
ROG100's Avatar
Stefan,
Your parts will be there before 12 noon tomorrow.
Roger
Old 02-29-2008, 06:01 PM
Stromius
Stromius's Avatar
Thanks Roger...you are the man! What a fix to a 928 for under $50...what's this world coming to?!
Old 02-29-2008, 07:31 PM
Tom. M
Deleted
Tom. M's Avatar
Ahh ever the optimist..you haven't put the parts on yet..so your $ tally is not yet ready... ..
Good luck ...
Old 02-29-2008, 07:48 PM
ew928
Owns the Streets
Needs Camber
ew928's Avatar
I like the factory 928 hose for the overflow. The pre-bent bit puts much much less pressure on the dainty breather adapter. On my cracked breather adapter using an aftermarket straight hose, part of the lower screw thread of the adapter stuck in the radiator. Guru who fixed it used a pick to work the broken part out.
Otherwise the fresh adapter would not screw all the way into the rad.
How did I surmise the straight hose maybe putting stress on the adapter, I gathered from looking at the abrasion mark on the hood where the hose was rubbing against it.
Keptun Kewlant
Old 02-29-2008, 08:24 PM
fraggle
fraggle's Avatar
You did better than me. I was planning to purge the power steering rack with new ATF and clean up the filter/reservior in parallel with my t-belt job. Guess which job I done first.
Wife fires it up, I eat a pile of ATF, as I'm watching under the hood to make sure nothing goes wrong, and run around in a panic to clean it off of EVERYTHING so it doesn't etch the fender, hood, roof, etc...
Quick Reply: First 928 facial
