Why does my Defrost BLAST?
when i turn on the defrost i have ZERO fan speed control. it is wide *** open and full speed. plenty of heat but no fan control???
a/c works perfect and was completely redone recently.
ALSO, when the slide controls are in the "OFF" position i still have air coming thru the vents. it feels like outside air like???
thanks for your wisdom..
Administrator - "Tyson"
+1.5 for Porken
Under the Lift
Defrost beahvior is normal.
The fan is always running when the ignition is on. (Owners manaul, page 49) This is a common feature to assure air is flowing through the cabin to reduce the chance of CO poisoning should a leak develop in the exhaust system.
You can close off the side and center vents with the levers in them. The defrost vents and floor vents cannot be closed. (Owners manual, page 47)
okay, i guess those are some of the pages that are stuck together in my owners manual. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
i'll take from the responses you guys are telling me to "read the damn owners manual"..![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
i'll go ahead and add a new owners manual to this ever increasing list of crap i've got to do..
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
okay, **** OFF.. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
as i stated in an earlier post, it was stuck together when i got it..
i'm more of a color picture dude so although i may have been tempted while reading the engine specs, i did refrain..![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
you guys are twisted...
Rest in Peace
