928 Forum 1978-1995
Sponsored by: 928 Specialists
fuel filter replacement
Old Feb 14, 2008 | 01:43 AM
jonny_five's Avatar
jonny_five
6th Gear
Default fuel filter replacement
tomorrow i will be attempting to get rid of the buzz coming from my fuel pump. it has been buzzing for 2 years now, ever since the guy i bought it from replaced the pump. my question is about the fuel filter. any tips? will i have to drain the tank? disconnect the battery? ha ha i dont want to lose this car too...
Old Feb 14, 2008 | 01:48 AM
RyanPerrella's Avatar
RyanPerrella
dont need to drain the tank, pretty simple operation although one of the nuts maybe frozen on from many years without replacement.
Old Feb 14, 2008 | 02:15 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
Squeeze the hose that runs from the tank outlet to the pump with your fingers. If it is supple and relatively soft to the touch, clamp it off. If it is hard and stiff, you'll need to drain the tank first to replace the hose.
Old Feb 14, 2008 | 09:14 AM
LT Texan's Avatar
LT Texan
Originally Posted by jonny_five
tomorrow i will be attempting to get rid of the buzz coming from my fuel pump...
I worry about mine not buzzing!!!
Old Feb 14, 2008 | 12:33 PM
Jim bailey - 928 International's Avatar
It is highly unlikely that the filter has anything to do with the pump noise. If the filter were restrictive you would have issues when trying to drive 80 MPH and there was not enough fuel volume to allow that speed. Possibly the rubber isolation mounts for the pump are broken and the pump is hitting the metal lower pan ??
Old Feb 14, 2008 | 12:43 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
I thought they were supposed to buzz.
New pump and filter on my 81, still buzzes.
Old Feb 14, 2008 | 02:15 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Mine started buzzing a couple of days ago, then stopped buzzing the next day. Whatever.
Old Feb 14, 2008 | 02:35 PM
the flyin' scotsman's Avatar
the flyin' scotsman
my FP buzzes after long distances; almost like its getting warm from working for sometime. When cold or only short distances it doesn't buzz.
Buzz or no buzz it works fine............pressure is always good; touch wood.
Old Feb 14, 2008 | 02:42 PM
If your pump gets louder and louder as you drive be sure that the tank vents are working and allow air to enter the tank as the fuel is consumed . Some have collapsed the fuel tank / get a loud rush of air into the tank when the cap is removed after a long drive.
Old Feb 14, 2008 | 03:38 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Thanks for that tip, Jim. I was surprised when my pump started making noticeable noise the other day, but surprised again when the noise was gone the next day.
Old Feb 14, 2008 | 03:44 PM
DSC928's Avatar
DSC928
Originally Posted by the flyin' scotsman
my FP buzzes after long distances; almost like its getting warm from working for sometime. When cold or only short distances it doesn't buzz..
same for my GTS.
Although, previous S4's FP got noisier as a precursor to dying. So keep an eye on it.
Old Feb 14, 2008 | 05:40 PM
JHowell37's Avatar
JHowell37
My pump, check valve, filter, and the small hose are all new and for some reason, some days it buzzes, and some days it doesn't. I'm not too worried about it, but I will check the vents when it warms up some.
Old Feb 14, 2008 | 06:47 PM
Daymon66's Avatar
Daymon66
well that explains the buzzing i have been hearing that makes me panic...
nice to know it's kinda normal..
