My CS wheels looks like new again! :)
The Decal King
I spend all day to the wheel repair shop but it worth it!
We also cut 1mm from insite the wheels in order to clean them from any powder coat remains!
Now they looks as good as new again!
Regards
Lefteris
Regards
Lefteris
The Decal King
Very nice!
I need to find a local wheel shop that is capable of this kind of work.
I had my phone dials restored by a place in...Cambridge maybe? Good job, powdercoat under clear coat. I'll see if I have any addt'l info on them, but I just found them via a web search. They listed a number of resto clubs and projects on their credits.
The Decal King
Thank you all
I have 225 at front and 245 at the rear (standard CS/S4/GT sizes) and works fine, if you wont your 928 for wet/dry road use, those sizes are perfect.
I will go for a new paint only on the hood at the end of the next week so I will post an update for this in the next weekend!
Regards
Lefteris
Regards
Lefteris
The Decal King
Agggrrrrr, I've just check the sensors and they put them wrong, the 3.0 bar rear ones at front and vice versa.... now I need to go back tomorrow and take off the tires againnn
The Decal King
I remove them by myself and because I was sure that they will have a problem with this I bring my tools along
First I WD-40 them the night before and then I use those tools, they came off easy.
I give them new O rings and told them to place them back the way they was but as I use to say, if you wont something to be made correct, you better do it yourself... and I was right, my bad that I don't check them when I was still there...!
Regards
Lefteris
