928 Forum 1978-1995
Sponsored by: 928 Specialists
WHAT HAPPENS when you advance the cams all the way?
Old 01-28-2008, 04:08 PM
surfridermason
surfridermason's Avatar
Location: Philadelphia, PA , USA The Great Fighting City of Brotherly Love
Default WHAT HAPPENS when you advance the cams all the way?
Originally Posted by Lizard931
I am pretty sure that I am correct on this, though someone else (porken) may correct me.
If you advanced the cams, you will have more bottom end grunt, but if you retard them you get more top end. I also would not go past about 4º either way without other changes being made.
[surfridermason]
I think you have that backwards....Retard moves the power curve to the bottom of the rpm range...BUT LET'S FIND OUT FOR SURE. Does anyone have a quick answer?
Old 01-28-2008, 04:12 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
As I understand it...."Advancing and retarding the cam can move the power band up or down a few hundred rpm. Advance for more bottom end and retard for more top end. ..."
Old 01-28-2008, 04:13 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
It goes BOOM! Klack Klack Klack! GASP HISSSSSS.....
Old 01-28-2008, 04:19 PM
Lizard928
Lizard928's Avatar
Ok, So Jim and I are on the same page with what the effect of advancing and retarding the cams do.
that is 2-1 so far,
Still waiting for Porken's and/or Louies responce.
Old 01-28-2008, 04:20 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
Hey you said all the way! key phrase "all the way"
Old 01-28-2008, 05:28 PM
AO
Supercharged
AO's Avatar
What MY car? On the 32V you will eventually hit a point (where?) where the valve and piston interfere with each other and cause major damage ala Mong's description.
I believe you are safe at 4º, so all you are likely to accomplish is to shift the power-band up (retard) or down (advanced) int he RPM range. At some point, I would think you will begin to see an effect on overall power, but I'll defer to Ken or Louis.
Old 01-28-2008, 05:45 PM
mark kibort
mark kibort's Avatar
It took about 3 degrees crank to make my passenger cam equal my driver cam.
i got a near 5-7hp gain. (1.5 degree cam advance, and about .3mm of valve depression at 20degrees ATDC) Now, both cams are at 2mm at 20degrees
mk
Old 01-28-2008, 07:02 PM
the flyin' scotsman
the flyin' scotsman's Avatar
Advance lowers the power band giving more grunt low down...........I did my car using Porkens great cam timing tool. Retarding the timing is a little more tricky but still very doable.
Old 01-28-2008, 09:27 PM
Lizard928
Lizard928's Avatar
lol, looks like I was correct in my memory on the subject.
And I run 1º retard on both my cams.
Old 01-28-2008, 09:30 PM
Lizard928
Lizard928's Avatar
Also i know that Porken has run his cars with upto 8º of adjustment, however iirc he did have some notable pinging in warmer weather with that.
I say 4º is a safe zone to go to, without having to worry about breaking things due to not being fully aware.
Old 01-28-2008, 10:29 PM
surfridermason
Right then I totally goofed,...Now I know what I'm doing tomorrow night if not wed night! LOL
Lizard I owe you one...you just fixed my bass ackwards timing setup...I can't wait to drive the car now!
Old 01-28-2008, 10:30 PM
surfridermason
I will set them in the middle best I can, trying to find the original wear marks from the factory....Until I get my paycheck next week....Then I'll get that porken setup....for some precision around here! What's the best way to get at the driver side cam gear without loosening the power steering adjustment block and removing all the belts in the process? Or is that the only easy way to do it properly?
Old 01-28-2008, 11:07 PM
the flyin' scotsman
that assumes the cam timing was altered after the factory.........or did I miss why or where he's at?
Old 01-29-2008, 09:31 AM
surfridermason
The timing on the chains was never modified[to my knowledge]. Why can i just use the Porken setup by itself...After all, it uses the offset on the cam gear mounts to find 0 doesn't it? And if the cam sprocket were never moved (internal ones with the chains) I shouldn't have to move them should I? I mean it's not a big deal, and I wouldn't mind learning how to use the gauge, but I'd prefer not to....
Old 01-29-2008, 07:50 PM
the flyin' scotsman
You can use the Porken cam timing tool without removing the cam covers.
The timing is altered by varying the cam position relative to the cam tbelt gear. Look at Ken's site which includes instructions of advancing and retarding cam timing. The cam tbelt gear is bolted to the exhaust cam so varying its timing also varies the intake and overall cam timing through the chain.
It took awhile to figure out how its done just reading the instructions but with tool in hand all becomes apparent...........just keep in mind how a 4 stroke engine works and you'll be fine.
Quick Reply: WHAT HAPPENS when you advance the cams all the way?
