928 Forum 1978-1995
Sponsored by: 928 Specialists
Low Speed Lurching. Cause???
Old 01-31-2008, 05:22 PM
  #46
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Yes Dan the decel valve was to limit pollution it is called a vacuum limiter 930 110 173 00 by Porsche. It was also fitted to the 78-79 USA models.
Old 01-31-2008, 06:53 PM
  #47
Chuck Schreiber
Chuck Schreiber's Avatar
Funny,
I feel this on the GTS which is new to me and though something was wrong. If you lug in first gear I can feel this bigtime. NEVER happened in the 79. It seems a lot smoother and easier to opporate at lower rpm at parking lot speeds. BTW, both cars are 5 spd.
Old 02-01-2008, 01:30 PM
  #48
6mil928
6mil928's Avatar
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
Chuck the rims on the OB look good.
Old 02-01-2008, 04:55 PM
  #49
John Speake
John Speake's Avatar
The fuel cutoff of the LH under deceleration can be switched off in the software, without loosing idle speed refulation or auto'box speed drop. This might be worth a try.
If anyone wants to try a test chip, let me know. Or anyone with a SharkTuner can make one for you. Just go into the "Parameters" screen and switch off " Cut off fuel under deceleration".
Old 02-04-2008, 12:41 PM
  #50
Chuck Schreiber
Thanks Jason, They'd look good on your identical 81 too!
Old 02-04-2008, 12:44 PM
  #51
V2Rocket
Rainman
V2Rocket's Avatar
i always figured that my car would lurch because it was idling enough to keep the wheels moving and the wheels were moving just fast enough to keep the engine at the right speed...lol
this also sort of happened in my infiniti Q45 automatic, it was the fuel pump tho.
Quick Reply: Low Speed Lurching. Cause???
