New MAF = new car + lesson learned
Ahem, excuse me, can't conceal my excitement, but I'm getting way ahead of myself.
Since I bought my 928 almost 2 years ago it has had an annoying occasional hesitation. Over the past 6 months it got progressively worse, despite my efforts to fix it.
Finally about a month ago, John Speake wrote me and recommended I have him check out my MAF and possibly re-calibrate it. Having tried a million things I was slightly sceptical but also slight desperate, so last thursday I removed the MAF, wrapped it up and send it to England.
Saturday (yes, saturday) I got a call from John - my MAF is indeed way out of spec. if I want a replacment send? Oh yes! Monday I receive note that it has been send, Wednesday at 7:30 in the morning I have a new MAF - less than a week total. I immediately install it (without waiting for installation info from John - oops
), and head of for work.AMAZING change - the car is a rocket. Even at 120mph it still accelerates like shot out of a canon. At the first red-light I discover a problem: It won't idle. Get in touch with John and he immediately responds, that I need to adjust CO - my mechaninc thinks the same, so off I go to the shop.
First reading is 14.5 - oops again. After turning the pot-meter all the way back it's down to 6.5 but still way out of spec. We start testing everything from fuel pressure to LH brain - no luck. As a final resort I suggest fiddling with the MAF pot-meter (though it's not supposed to be connected for S4 and above). Imagine our suprise when the slightest turn of the **** drops CO to 1.5-2. Weird but great!
Re-assemble the air-box, in comes the air-filter and the CO jumps to 6.5 again, almost choking the engine. Hmmm. Mechanic notes I got the filter in upside down (Apparently the arrows on the side do not indicate air-flow) so we flip it, and CO drops again.
Lesson learned: Apparently the filter touches the MAF when upside down, preventing air-flow at low RPM.
Anyway, John is my man of the day! I sincerely recommend his services to anyone with rough running/hesitation issues with the 928.
If you like playing with it, 70 dgrees F. is about 2k ohms. Check your plugs.
<img border="0" alt="[bigbye]" title="" src="graemlins/xyxwave.gif" /> <img border="0" alt="[burnout]" title="" src="graemlins/burnout.gif" />
I hope I will be able to help you out !
Any exchange MAF from me will have the idle mixture pot on the MAF set to a nominal value. The car will then run and idle OK on your 86.5, but you will need to do a final "tweek" of the pot with an accurate CO meter. And maybe an adjustment of idle speed.
The procedure is described on page 24-204 of the Workshop Manual. It says you need some special tools, but with a bit of ingenuity you could manage.
What is essential is an accurate CO meter.
Best regards
