R&R of combination switch anyone?
I may have a defunk switch that you can have the stalk from. Mine was not functioning properly due to some of the pins moving in the back of the housing. Got a replacement from a Rennlister but I did drill out the rivets and looked inside - if I recall correctly all of the stalk functioning parts were in place.
I will not be able to check until the weekend but if interested PM me.
Electron Wrangler
Bill et al
I have removed the switch again and it is indeed a 911 part number 964.613.332.00 part.
I'm going to try to fix it if I can get a stalk to try out (Roger as above or on eBay) If not it at least seems a new (possibly used) will be available.
Alan
Alan
Electron Wrangler
Roger - that is a part that commonly breaks - but mine is OK.
I need the whole stalk lever that this part engages into As below.
Alan
Alan
Electron Wrangler
For a very small price Roger did supply me with the stalk from his broken switch (thanks). This stalk still had the main spring & cancel wings intact (see the difference...).
I did compare it to the GTS version and though the business end inside the switch is basically the same - the stalk itself was a different length (a longer offset from the steering column before it curves) - presumably due to the second short stalk (OBC) the main stalk was made longer.
After some investigation (and a trial on the broken version) it became apparent that the stalk part is removable from the rotating switch activator by pressing out a friction pivot spindle...
So I was able to swap the GTS lever to the earlier style rotating switch terminals. I also swapped the spring detent unit because the GTS version uses a different kind of nylon that seemed to work more smoothly...
Now self cancelling works - I need to pull the switch again to adjust the high beam switch which is now giving me high beams all the time... but I know how to fix that since it happened before...
So some work - but the combination switch can be repaired!
Roger Big thanks!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Alan
Roger Big thanks!
Alan
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
Alan
Roger Big thanks!
Alan
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Alan:
Glad it worked out in the end. This is a great because I know that there are many of these assemblies that are replaced because one of the various features is broken - in my case it was the cruise control stalk - but now we can mix and match parts as necesary.
What screws did you use to replace the original rivets?
Electron Wrangler
I drilled out the rivets on the front plate side - then punched them out through the back - then countersunk the holes into the cover plate...
I used countersunk self tapping screws sized to fit to resecure the front - they are flush to the front face...
Works quite well & pretty easy to do... Switch reassembly is a bit tricky but you get good at it with practice...
Alan
Alan
Basic Sponsor
Jason,
Ice formation maybe - use a pick.
Roger
Roger
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
