Average Cost of Powder Coating the Spider
Administrator - "Tyson"
Cost $150 for mine - he ground off all of the weld seams before coating.
Man of many SIGs
You can grind the seems very easily if you use a standard grinding wheel that is made for steel. Then follow up with a blending wheel or some 120 grit sand paper.
none-the-less all the powder coating i have had done they charged me a fairly cheap rate for the powder coating BUT the prep was was where the cost was.
so to answer the topic question, depending on prep work somewhere between 125 and 200 would be normal in this part of the country.
Consider ceramic coating (aka Jett Hot) instead of powder coating.
Same price, but ceramic coating has additional insulating properties.
Can Ceramic Coating work on wheels, etc? Besides the insulating properties, what are the advantages? Got a recommended Ceramic Coating Shop here in San Diego?
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
$300.0. To have the whole motor powdercaoated locally.
intake, spider, plenum, water bridge, cam housing, heads, misc. brackets and oil pan. Left the block in its normal finish...headers were "jet hot' ceramic coated.
