help with stroker questions........please
#32
Road Warrior
probably take that long to line everything else up anyway... the time goes fast... when I spoke w/scat 2yrs ago, they had no issue building a single crank fast. but I think moldex does a better job of hardening or uses a better steel... there is a debate on whether 6 or 8 counterweights is best too. I used 6, devek uses 8, others use 6 or 8 too... in fact, most everything on these is debated at one time or another
we're master-debaters, hahaha
#33
#35
so now that I've got all these measurements, now I'm struck on a few things.
my block is stock deck height, 9 and 1/4 inches. (metric conversion...232.75mm +?)
if I use a 95.25mm stroke crank, and a 6 inch rod, what is the piston pin (centerline) to piston top measurement I can use? (remember, in this excersize, I am using 16V heads, to be flat tops with just two valve notches with zero deck protrusion)
Sterling is advising that the 6 incher will push into the ring package, so what are my options?
Piston diameter is no big deal, as there are a few Chevy 400 piston measurements that would work for ring sizing. That would make ring purchasing easier.
Anybody care to take a stab at this?
--Russ
--Russ
#36
Deck height is measured from the main centerline to the top of the cylinder.
232.75mm
Take one half the stroke of the crank and subtract from the deck height and you will have how far down the cylinders the centerline of the big end of the conrod is at TDC.
95.25mm / 2 = 47.625 mm
232.75 - 47.625 - 185.125mm
Subtract 6" (rod length), and now you have how far down the cylinder the centerline of the small end comes to rest at TDC.
185.125 - 6" (152.4mm) = 32.725 mm
For zero piston deck height, the distance from the centerline of the wristpin to the deck would be 32.725mm (1.2884")
This may not be optimal depending on what thickness gaskets you run.
WARNING: I'm not an engineer. You rely on my math at your own Peril
At any rate, I think this will get you close Russ. Definitely double check my mechanics and my math.
232.75mm
#37
Also, I think one of the Wisconsin strokers was running pistons where the wrist pin boss went up into the ring package. From the pic I saw, it looked like the scraper was installed after the wrist pin since it spanned the wrist pin boss. It looked pretty cool, I think it was a JE. Don't know if this would be considered a "streetable" set up, but it definitely looked "all business".
#38
The GTS pin center to top of piston is I believe 39.07 mm , 944 2.7 liter 104 mm piston 40.75mm , the 3 liter 944/968 is 36.05mm , the 928 4.7 piston is 42.75 mm. You must use a short piston as well or the shirts hit the counterweights. The GTS and 3 liter 104 mm 968 pistons are much shorter than the 4.5,4.7 or 5 ltr pistons because they have to be . Short pistons are harder to keep straight in the bores and coupled with the additonal side loading of the longer stroke crank it is less than ideal but there is only so much that you have to work with.
#39
Jim wrote:
Jim, you have just summarily summed up the totality of what a stroker build up is all about.
#41
232.75mm
232.75mm
Adam---
this is exactly the math I'm coming up with.
yes, the oil ring will have to be across the pin, but i will discuss this with JE nest week.
thanks all for the help and guidance.
--Russ
#42
You may want to look into Childs & Albert. Since you were a drag racer I'm sure you know who they are. They have a lot of experience making high quality pistons with the rings in the pin boss. The piston section in their catalog on their website shows some examples. Check 'em out.
Regards, Hammer
http://www.childs-albert.com/catalog...om_pistons.pdf
#43
Hi Russ,
Regards, Hammer
Regards, Hammer
too many numbers going thru my head to keep this straight anymore---must be old age or something...
Thanks---Russ
#44
Hi Russ,
I found the pic I was referring to, it's one of Todd's builds:
http://www.erik27.com/todd/427/Pisto...s/_DSC0492.htm
Same idea as the C&A pistons Hammer posted a link to.
Just a reminder to make sure to calculate your static C/R before ordering up the pistons. If you've built domestic motors in the past, its easy to take for granted that you have a wide variety of head gasket thicknesses to dial in your C/R, you don't have options like that with the 928 (unless your willing to go with Cometic gaskets which have a checkered history with the 928). I know I'm probably stating the obvious to you Russ, just want to make sure you've got a heads up on things like this. Things that can be taken for granted on a domestic build will sneak up on you when building one of these stroker motors.
#45
Hi Russ,
I'll should know something about piston builds later this week (from JE and C-A).
Thanks-
--Russ
