928 Forum 1978-1995
Sponsored by: 928 Specialists
Intermittent Wipers - couldn't they be better?
Old Mar 4, 2003 | 01:52 PM
  #31
PorKen's Avatar
PorKen
Inventor
Post
Well, my local VeeDub'ya store could not get a 3B0-955-531, and the dealer had to order from LA for $47 (=list price everywhere), so I went a searchin' on the infernet and found prices from $68 (with IPD sticker) to $20. <img border="0" title="" alt="[Eek!]" src="eek.gif" />
E-mail me if you want the $20 link (don't want to step on any toes).
For a simple stop-light speed reduction function, which would only be triggered if set on low speed wiper:
Put a relay that would be triggered by the brake light feed, which would interrupt the low-speed feed and route it through the intermittant feed .
Old Mar 4, 2003 | 02:55 PM
  #32
Jimbo's Avatar
Jimbo
Post
What is they best way to get the old relay out?
Has anyone made their own tool?
Old Mar 4, 2003 | 04:43 PM
  #33
PorKen's Avatar
PorKen
Inventor
Post
Jim - I was able to extract mine by wiggling the relay gently, up, down, left, right and pulling slowly.
I've been driving around town today with the horn relay swapped rear wiper (drizzling). I'm going to keep it this way!
It only wipes once, it's faster(?), and the blade stops just 2" from the edge, versus the 3-wipe which would often stop up to 6" from the left hand side!
Old Mar 4, 2003 | 07:02 PM
  #34
Jimbo's Avatar
Jimbo
Post
Alan,
You might want to retitle and relist this post. I think almost everyone will get one!
Jim
Old Mar 4, 2003 | 08:02 PM
  #35
Normy's Avatar
Normy
Cool
Jim-
Auto parts stores often sell a tool for removing stubborn spark plug boots. This is nothing but a strip of metal bent 90 degrees at the end. It can be used to remove sticking relays too.
To use this, DISCONNECT YOUR BATTERY GROUND STRAP, and slip the tab under the bottom of the relay and pull back.
-Don't hit yourself in the face like I did!
Normy
'85 S2 5 Speed
Old Mar 4, 2003 | 09:16 PM
  #36
Jimbo's Avatar
Jimbo
Post
Normy,
Thanks for the warning!
Jim
Old Mar 15, 2003 | 12:32 AM
  #37
Eric Dvorak's Avatar
Eric Dvorak
Post
Relay removal:
1. weld custom made 2' long black pipe T-handle to top of suspect relay.
2. Move pass. seat to full rear position.
3. Get willing companion to sit on front edge of seat firmly gripping T-handle.
4. Start car, put in 1st gear and FLOOR IT!
(This does not work for bad fuel pump, EZK, Exc. relays) :^0
Old Jan 4, 2016 | 04:43 AM
  #38
danglerb's Avatar
danglerb
Is 3B0-955-531 still the relay to look for?
Old Jan 4, 2016 | 05:53 AM
  #39
murray928's Avatar
murray928
VW/Audi 99 relay is the one I have used in my 928. It is programmable and works perfectly for me. Installed 9 months ago no problems.
Old Jan 4, 2016 | 06:59 AM
  #40
kurt_1's Avatar
kurt_1
When putting the Bosch Nr (0 986 335 058) of the relay into this site:
http://www.findpart.org/part/bos-0986335058/
one gets the correct VW Nr (1HM955531A) as equivalent part BUT also this P/N:
"PORSCHE 928 615 101 01 (92861510101), Relay, wipe-/wash interval"
Seems such a relay is also used for the wipe-wash-function (can't look at my car right now). Can anyone verify this?
Kurt
90 S4 satin black metallic
928 OC Charter Member
Old Jan 4, 2016 | 03:05 PM
  #41
Donald Smith's Avatar
Donald Smith
Hi guys. A buddy of mine has a used one for sale on the Quattroworld Forums. $30 shipped to U.S.A. I told him to put a hold on it. LMK if anyone would like it and I will forward you his co-ordinates to Paypal him.
Old Jan 4, 2016 | 03:25 PM
  #42
wpgshark's Avatar
wpgshark
I'll take it
Old Jan 5, 2016 | 01:23 PM
  #43
kurt_1's Avatar
kurt_1
Never mind, I checked it out and it turns out that the parts reference site got it wrong: the 928 P/N is the actual relay that is used in our cars for the intermittent wipers which requires the potentiometer.
Kurt
Old Jan 5, 2016 | 02:13 PM
  #44
dr bob's Avatar
dr bob
Chronic Tool Dropper
For others playing along at home, I think Roger carries the VW relay for our convenience.
Mine works great, BTW.
Old Jan 5, 2016 | 06:27 PM
  #45
Adk46's Avatar
Adk46
I have a problem with wipers, of any sort. I use RainX.
