Headlights going crazy
A week ago I hit a bump, PA roads are really bad this time of the year, actually all the time but especially now, and the lights started to cycle up and down. They wouldn't stop untill I turned the key off, they were then OK untill tonight when I turned them on and they started cycling again this time they stopped when I turned them off but would start again when turned on. With them off I attempted to run the headlight motor through a cycle by hand but as soon as I turned it a little it took off through one cycle and then everything was OK.
I think the position indicator, if there is one, must need adjustment, does anyone have any info on this, any help will be appreciated.
TIA
<img src="confused.gif" border="0">
TIA
Check the relay in the main fuse/relay board first Dave.
Then check out the headlight switch.
The motor contains the contacts that signal on/off of the raise/lower function.
Search the archives here for several recent discussions by others with a similar problem as yours.
