LH 2.2 MAF/CO adjustment LED (85-86 US)
#61
i'm a new 1986 928 owner, and I built my own adjustment tool and Blinkr per the instructions. Blinkr only blinks at MAF pot setting of 2 ohms. When I temporarily adjust MAF to 380 ohms, startup from cold is wild until O2 sensor warms up.
Is MAF pot setting of 2 ohms a sign of a failing MAF or O2 sensor? Could this be related to my high NO emissions?
I started a related thread with more details:
https://rennlist.com/forums/928-foru...on-blinkr.html
#62
A setting of 2 ohms would give a very weak mixture - if the MAF is aged it would be even weaker.
Aged MAFs would need more pot resistance.
Sounds like the measurement system is the problem.
#63
The MAF could very well be "aged".
Thank you for the assistance,
John
#64
The fact that the car generally runs better with the pot at 386 ohms even when the blinker says it is wrong, suggests a problem with the measurement.
Have you tried disconnecting the O2 sensor and adjusting the pot so the engine idles well and responds OK to the throttle ?
Hi NOX suggests a weak mixture as per our email conversation.
#65
#66
Have you checked the basics like fuel pressure and engine vacuum at idle ?
The problem could be a MAF problem, they can suffer a form of thermal runaway where the output will be higher than it should be. This enriches the mixture and would force you to turn down the pot to compensate.
