928 Forum 1978-1995
Sponsored by: 928 Specialists
belt tensioner light oddity
Old 02-25-2008, 02:10 PM
Mike Frye
Craic Head
Mike Frye's Avatar
Originally Posted by Bill Ball
Well, I hope this is all's well that ends well. If they never told you to come back at 2000 miles for a tension check, I would still avoid them in the future. Two hours may be book, but is is an hour longer than it should take.
I'd also check the odometer in vs. out.
You may have gotten "Bueller-ed"
Old 02-25-2008, 02:21 PM
rickjaffe
rickjaffe's Avatar
eurowerke did it initially with the water pump. they said because of their $900 tool, it wouldn't need an adjustment. it did three days later. That's one of the reasons I didn't want to take it back to them.
Old 02-25-2008, 02:51 PM
Herman K
Herman K's Avatar
Default Follow up on Kobe
PM send
Old 02-25-2008, 03:00 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Oh, I forgot that. Wow! You must be in better hands now with koby.
Old 02-25-2008, 03:32 PM
Big Dave
928 Engine Re-Re-Rebuild Specialist
Big Dave's Avatar
had koby readjust the belt. they did it quickly (dropped it off friday, picked it up monday) for a reasonable fee $189, two hours. The problem seems to be fixed. I'll use them again when the need arises. thanks
2 hours to check and adjust the belt?
The problem is why the belt became so loose, not only the fact that it was loose.
Hopefully the belt is ok, but you should check it again soon. Make sure it's tracking straight on the pulleys, too.
Quick Reply: belt tensioner light oddity
