The next best thing........
.......to a shop manual is you guys! Once again the info posted here has saved the day.....and $$$$. Had a window switch that has been quirky lately and would go down but not up w/out tremendous patience and jiggling of the switch. The archives had the info I needed to pull apart the switch (VERY carefully) Luckilly all it took was some cleaning of the contacts and viola! Works good as new! Thanks again Rennlist!
PS. Why doesn't removing the fuse (#25 as per the schematic in my manual) prevent power from going to the window switch as it shows?
Had to disconnect the battery instead.
Consider becoming a Rennlist Member. This forum has been a goldmine of information! $17.95/yr. is a bargain! Membership fee goes towards maintaining and running the website and its various mailing lists.
