oil pressure sending unit nightmare
Craic Head
Isn't a pegged 5 bar reading an indication of reversed polarity on the wiring? I thought I read that somewhere. I would try reversing them first to see what you get.
Craic Head
Craic Head
Yeah, I know. I was trying to confirm my own idea of the reversed polarity thing. We're on the same page, I just haven't had this particular problem, so I'm suggesting it second-hand.
Mine was so tight that I finally removed the whole thing and put the sender in a vise, squezzed the hell out of it and then used a wrench on the adapter- still had to use a cheater bar.
When I replaced mine I didn't worry about the polarity that much as there are a number of people that say it doesn't matter. On my '87 it matters a lot! With a fully functioning sensor and the wireing reversed, I gt a constant oil pressure warning. Once I changed the polarity it worked fine. BTW my sending unit came off on its own, without the pressure transducer part. I was all prepared to catch the flying springs and everything, but it just came off with very little effort.
On a cold engine, the oil is at its highest viscosity and is going to give a 5 bar reading. As the engine... and the oil warm up, the pressure will drop accordingly. Once the engine is fully warmed up blipping the throttle makes the oil pressure rise and fall.
Jerome
Jerome
Thanks for the input guys, Tom if you go back to my first thread for this nightmare you`ll see I pulled the oil filter first. I have now dropped the Alt. as well. Cut the old unit off with my dremal tool, leaving the hex nut to the sender but the rest of it is gone. I just came in from putting an impact socket on it because I have now cracked 2 standard craftsman sockets prying on the beast. A impact socket that fits tight, a 18" breaker bar and 2` steel pipe and I still cant get either of them to move. My neighbor came over because he hasn`t ever heard me using the kinda words he was hearing from my garage. He sat down a put his 230 lbs against it and then I jumped in and we still haven`t been able to budge this thing. Once again, all that is left up there are the two hex head nuts, they are not lined up together and the sending unit hex is larger than the relif valve assbly hex head. I`m going to see if I can rent a impact wrench from the tool rental, hopfully they will have a 1/2" drive with lots of power, if not I`ll be having to purchase one. Can anyone shed any light on which impact wrench provides the most grunt, electric or air???? HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! toofer
Oh, I wanted to add that engine temp made no diff to the location of the meter. It stayed pegged cold, hot and everything in between and yes I checked all other possible cures before taking this approach. I don`t love working from the under the car, closed in spaces and I have never got along, but a man does what he has too. toofer "I`m trying to think but nothing happens" as Curly put it!!!!!!
Electron Wrangler
When you swap the wires - you are not changing the sender polarity!
The oil sender/switch unit is combined it has 2 functions & 3 terminals - 2 obvious terminals and grounding via the threads.
The switch is between one terminal and ground and the sender is between the other terminal and ground. The sender controls the oil pressure gauge (variable resistance) the switch controls the low oil pressure light (on or off).
Terminal G is the sender (Blue/Yellow wire), terminal W is the switch (Black/Green wire).
Try just swapping these if they are incorrectly attached...
Alan
Alan
Last edited by Alan; 01-04-2008 at 04:27 PM. Reason: Fixed the error Big Dave points out in next reply...
928 Engine Re-Re-Rebuild Specialist
Alan...as Jerome stated, if the wires are swapped (i.e., incorrect), the pressure warning will trigger and the flashing light in the dash will illuminate. BTDT.
Electron Wrangler
Oh - Ok I mistated the behaviour but still - you can't just swap these - you aren't just swapping polarity of the sensor.
Alan
Alan
OK, I`ll go soak it down again with penetrating oil, WD-40 is what I`ve been using and then I`ll get medieval on it. Found an impact wrench, will pick up and try again tommorrow. I afraid to try heat. I`m thinking the PO must have used loctite on the threads. I`ve worked on cars, trucks, motorcycles, boats and ford tractors, good hydo training, and have only encountered this when someone used loctite in a location they shouldn`t have. I believe that heat is the only way to deal with that situation. I read somewhere heat turn loctite to a gas substance. PO was not big on keeping the machanicals clean nor the interior for that matter. I have just finished a total restore of the interior. grase baked on for 28 yrs isn`t easy to get off. Does anyone know if loctite will disapate if heat is applied to the area it is on?? Again, I have no idea if that is the case but what else could be holding it. The threads on my new sending unit are standard, could the relief valve have reverse threads???? I trying to think but nothing happens
HTML Code:
He sat down a put his 230 lbs against it .....
For the really tough nuts I use a 4 foot scaffold pole as an extension on the breaker bar.
This also means I am no longer under the car....
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Marton
