Do you have to use copper anti seize on rear axles
I'm finally just about ready to put my axles back in, but have not been able to locate copper anti-seize locally. They either don't have it or it's not in stock. I have regular silver anti-seize, which seems to have the same properties as copper anti seize, but copper is what's spec'ed by the shop manuals.
Is there a specific reason for using copper on the axle splines and thread? I'd like to avoid having to have it shipped, or wait for somebody to actually stock it, and if I can put the silver anti-seize on, I can actually get them put back in this weekend.
copper slip...
I never realized this was hard to get. The Autozone in your area shows this as a stocking item:
http://www.autozone.com/selectedZip,.../selectZip.htm
I have the permatex brand:
http://www.permatex.com/products/aut...ubricant_b.htm
I think I've been using the same tube for about 8 years. I used it last night installing some new iridium plugs in my Aprilia.
I don't know why the aluminum based stuff wouldn't work too.. as it will be between two pieces of steel.
Yeah, I called that Autozone and they said they didn't have it. I also called about 5 other auto parts store, and even the local VW dealer, and none of them have it. Either out of stock, or I get a "copper anti seize?" type of response.
Under the Lift
The whole copper versus "silver" anti-seize thing has me confused. Most general-purpose anti-seize compounds contain copper, aluminum and graphite.
Anyway, in reference to spark plugs, one anti-seize vendor has a chart that recommends zinc-based anti-seize for aluminum against steel. I don't put anything on spark plugs and only use copper type where called for.
http://www.sacskyranch.com/antiseize.htm
According to the WSM the copper-colored Optimoly should not be used on steel to alloy.
I may just be overanalyzing this, but these probably aren't coming out again for a while, and I'd rather it be as easy then as it was this time.
Under the Lift
Fabric: Permatex 133A (8143) is general purpose and has some copper in it and should work fine. Permatex also makes pure Nickel (77124) and Copper (09128) antiseize.
Well, I do drive mine in the winter. Anyway, they are in with what I have now. Considering how clean they were when they came out, it's not as if there's a whole lot of water getting in there, you could probably just put grease in there and it would be fine.
I was told one time that copper anti-seize is special order only... I walked across the store and picked up a tube off the shelf, walked back and said "Oh yeah?" The guy behind the counter didn't say another word.
