What is standard boost with Murf Kit?
What level of boost does the standard pulley provided in my stage 1 kit give? I never thought to ask!
Stage 1 is 8 psi. If you're not getting it, tighten the belt!
Range Master
Pepsie Lite
Pepsie Lite
I have seen as high as 10 psi on a cold spring day. In the summer I see approximately 7 or a bit more, on the boost guage.
7 is what Tim promised me. I have an early (commercial) kit. I am very happy with the performance. Pully diameter determines the pressure (within a reasonable range). Tim has likely several options available by now. I wanted a conservative one when we were discussing my kit build up, (several years ago).
The Wisconsin guys are the BEST to work with.
