Oil Level.
On this motor, how common are false highs and lows?
How much does leaning the engine just a bit make on the level on the dipstick? Side to side, front and back?
Thank in advance.
Side to side won't matter too much, but fore and aft will make a good bit of difference.
I have a feeling that side to side makes a bit of diffrence, otherwise I can't explain why when my car is leaning toward the passanger's side, it's a little bit overfull, but when it's level, it's a bit underfull.
I'm glad that the for and aft would make a good bit of diffrence. I thought I had run the motor way low on oil, added some, and now am WAY overfull. When I checked the dipstick the first time, the car was leaning slightly backward, and I couldn't find oil, at all. (motor doesn't run right now so thats OK)
I broke a t-belt, not my fault! I'm eighter in for a lought of work, or just a good bit of work.
Wish me luck, as I'm hopeing the US 4.7 is a non interference motor.
Awhile ago, my mechanic checked the oil level while my car was parked on a sloped area, passenger side high. He added 2 quarts of oil.
When I retreived the car I noticed it was blowing smoke at high throttle. Checked the oil level (with car level) - sure enough, 2 quarts over.
Had to use the oil change pump I use on my boat to remove those two quarts.
My advice would be whenever checking any fluid levels, make sure the car is first parked on a level surface.
