928 Forum 1978-1995
Sponsored by: 928 Specialists
1984 LSD unit
Old Dec 17, 2007 | 11:17 PM
Giovanni's Avatar
Giovanni
Default 1984 LSD unit
Can anyone tell me if this is an LSD and it will work in my 1989?
File Type: jpg
File Type: jpg
Old Dec 18, 2007 | 01:00 AM
largecar379's Avatar
largecar379
part number would help-----
should stamped on the outside of the small end (not the ring gear end).
---Russ
Old Dec 18, 2007 | 01:23 AM
123quattro's Avatar
123quattro
Looks like an open diff to me?
Old Dec 18, 2007 | 01:30 AM
ZEUS+'s Avatar
ZEUS+
+1 Sure does look open.
Old Dec 18, 2007 | 04:07 AM
Vilhuer's Avatar
Vilhuer
Ring gear must match pinion gear. This means automatic pinion gear will fit into automatic only and manual to manual only. Then there are year to year changes too like three different types of manual gearbox pinion shaft setups. Anything can be made to fit anything else but work needed will be too much to make any sense what so ever in some combinations.
Old Dec 18, 2007 | 06:49 PM
Jim bailey - 928 International's Avatar
That is an open diff, no limited slip...
Old Dec 18, 2007 | 07:27 PM
Giovanni's Avatar
Giovanni
Thanks for the headsup. I found it on craiglist for $350 offered as an LSD
You guys safed my wallito some monito again.
Old Dec 18, 2007 | 11:47 PM
123quattro's Avatar
123quattro
What a jackass. Maybe he Lincoln locked it?
Old Dec 21, 2007 | 02:05 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Just found this old pic that is relevant.
File Type: jpg
