What are the Largest wheels and tires for an '82?
Andrew--
the figures you requested:
front--
19 x 8 et 67mm
235/35/19
rear--
19 x 11 et 67mm
315/25/19
1/4 inch spacers on both front (not necessary, but it looks good) and rear (necessary, otherwise the wheel hits the lower shock mount)
I am told that you can run a 18 x 10 on the front, but may require fender mods.
can't run a 19 x 10 Porsche wheel due to wrong offsets.
hope this helps---
--Russ
front--
19 x 8 et 67mm
235/35/19
rear--
19 x 11 et 67mm
315/25/19
hope this helps---
--Russ
