FS: Oil Pan Rail to make dry sump pan
$185
This is a modified pan spacer that has an extra 1" of material in the inside area for welding fabbed stuff, it's 3/8 thick 6061 aluminum which should be a flatter, thicker, more weldable start than a cast 928 pan if you're inclined to make your own dry sump pan.
The actual part is boxed up for shipping, here's a pic of the CAD model:
I can assure everyone that Mike's Stuff is top notch CADCAM whatever machined stuff that almost looks to good to put on the car. He ships it like a professional and includes directions where applicable.
He is also a respected member of his own community, as he is a business owner of a successful Tool Manufacturing Company.
Thanks guys
Sterling, if nobody wants this it may wind up getting other stuff stuck on to it to become a proper dry sump pan after all. Are you still contemplating a tank to reside in the windshield washer area?
