injector problem...need info
I have an injector leak coming from the upper part.
It's not the hose or the clamps, but the leak is coming in the brownish-gray plastic piece after the connector.
I changed small and large seals not too long ago, and re tightened the clamps. Still nothing.
Should I buy another injector? Or is there something I'm not looking at?
Andrew
'84 928s
Andrew
'84 928s
Andrew, I had all of mine rebuilt. Sent the rail and injectors to rich@cruzinperformance.com If you send the rail he puts new hoses on and you don't have to monkey with it. I thought about replacing them (72.50 each X 8 = $580.00) But to have him rebuild $130.00 Go to the web site. Think about it. With one injector replacement your more than half way there. I was real happy with my results. Rich # is 1-231-796-5705
Chucker
1982 928 White <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
Chucker
I'm sure that you could work something out with him. Geive him a call. I put the number for his shop in the first post. Good Luck! <img src="graemlins/xyxwave.gif" border="0" alt="[bigbye]" />
I just received all of my Injectors back from CruzinPerfromance - total cost was $89 for cleaning, flow testing (as found and as left).
They even supplied new orings and pintle caps.
<img src="graemlins/yltype.gif" border="0" alt="[typing]" />
