Car keeps dying
#76
Congrats on fixing the charging issue!!! It has been a long time coming.
Your drivers side marker being out may be fuse related, check the fuse chart and you should find the fuse for that circuit, swap it out with a new one and see if that fixes the issue.
Same thing happened to me, drivers side, and waring on dash..........fuse looked ok, but I swapped it out any way and the light came on and the warning went off.
Good luck.
Good luck.
#77
Are each of the side markers on different fuses? I just noticed that my front passenger side marker is out in addition to my rear drivers side marker. It looks the two side markers on each side are on the same fuse, but maybe I'm missing something.
#79
