ignition switch wires
I am going to replace the ignition switch, but when I went to take the wires off the back plate came off and now I have no idea where the wires go. does anyone have a pic of the switch and which wires go where? Thanks
Lane,
This has come up before. Try search function. BTW when I changed mine, the wires were all attached by way of a big circular black connector. Did that burst apart and release all the wires? If so they should have a memory and you may be able to reconstruct the original configuration.
I searched for this and found others looking for answers, but none were given. The back piece up plastic came off releasing all the wires and I have no idea where they go.
Alright I just ran out to the garage and took some shots for you.
I hope that they help/work for what you need.
This is from an 85, however should be the same for you car. HTH
What a change! This happened to me 13 years ago (pre Rennlist) and the only advise I received from the PCA was "buy the workshop manual". It cost $425 and a lot of time to sort out the wiring. This makes the Rennlist membership the best bargain around.
Dennis
Dennis
Electron Wrangler
BTW - the wires that are the same colors are the same thing - the relative positions between these doesn't matter. They all connect together in the switch anyway.
This may help too https://rennlist.com/forums/showthre...eferrerid=6055
Alan
Alan
Electron Wrangler
For more detail: Terminal ID's should be marked on connector/switch body
Terminal 30 - 2(/3) x Reds are battery in (2 heavy duty(/1 thin))
Terminal 15 - 2 x Blacks are Ignition out (2 medium)
Terminal 50 - 1 x Yellow is Starter(relay) (thin)
Terminal X - 2 x Black/Yellows are Accessories (1 heavy & 1 med)
Terminal R - 1 x Red/Black is Radio Supply (medium)
Terminal P - Grey is Switch Off(0) Parking (thin-med)
Terminal 1 - Black/Red is key-in switch output (2 thin wires)
Terminal 2 - Red/Black(thin) is power in to key-in switch (thin)
Alan
Alan
Perry if you look at pic 1 you can see that there is a cover on the back, it is held on by 3 clips. He managed to pop that cover off the back, then they fell out.
I got all the wires back where they belong, so now I'm just waiting for my new switch, and hopefully everything will go back together without anymore hitches. This website saves the day once again. Thanks again Lizard931
