1ST GEAR START VALVE BODY
Steve - where are you at with the Valve Body?. The reason I ask is that my 84 has developed a 3rd to 4th up shift slip wich is also becoming steadily worse. According to the PO, the valve body has already been modified so, I'm thinking it's almost at it's end. Any luck w/a local shop?
Also, what is entailed in swapping out the valve body?. Complete R/R or in car install.
TIA
TIA
I too am interested in your Valve Body mod., please give us an update when you get a chance.
For me the below are as important if not just a bit ahead of the first gear start modification.
"The shift valve springs are changed to extend the shift points."
The added benefit of the modified valve body fixes in most cases the 3rd to 4th up shift slip and the delay engagement from park to drive,
____________________________________________________
Drew, the valve body change can be done with trans in the car.
Drew,
I can tell you that after installing my brothers transmission with the first gear start in it, just rebuilt by Steve, That this is an Awesome modification. The car really jumps off the line, I still have some adjustments to make now in shift firmness and kickdown but if you are looking to change the way your shark takes off this is the way to go. My brother could better explain it as I am usually driving a 3 speed and I am used to my shiftpoints at 60 and 105 under WOT, but my brother seems to like it very much.
I was seeing his shiftpoints as follows Under moderate throttle
1-2 4500rpm
2-3 4500rpm
3-4 just after 2-3 cause I have to get my foot out of it at this point cause I was going 90 in a 35 lol
I need to get back under it and retorque all the suspension bolts now that we have driven it, also I need to loosen the kickdown cable as it will jump right down a gear now as soon as you apply just a little pedal. So I am going to work on getting the shift points a little higher under WOT and a little lower under light throttle.
Great Modification Steve C.
Z
1-2 4500rpm
2-3 4500rpm
Z
Steve,
At this time the 1st gear start / recalibrated valve bodies are only offered with my rebuilt transmissions. The reasoning being it’s consuming too much of my time, as a transmission shop owner, head rebuilding and putting up a new building, time is at a premium. By this summer I will be ready to offer them again with a 2nd to 1st down shift modification.
Your 89 transmission assuming, it is the original, has a 2150RPM stall speed converter, how does the car feel on take off? I do offer higher stall speeds torque converters. The optimal stall is one that allows the car to launch at or slightly lower then the engines pike torque. You can check your converters stall by doing the following test.
The most accurate method for determining actual stall speed on a car is to launch the vehicle at full throttle, and note the rpm at which the car actually takes off (requires a partner watching the tach).
In choosing the right stall speed the weight of the car, rear ratio, engine torque and cam profile are factors.
Drew, T Max. You guys are on the top of my list for the valve body.
Hi, Jim,
I am glad your brother likes the way that transmission operates.
Drew,
If these shops can not help you let me know, I will
Aa Automatic Transmissions
Jerry Chase
4570 E Irvington Rd
Tucson, AZ 85714-2121
County: Pima
Phone: (520) 571-8050
Map it! Please use the Back button on your browser to return to these search results.
AAA Transmission
Martin Johnson
1146 E Jimmie Kerr
Casa Grande, AZ 85222-5008
County: Pinal
Phone: (520) 836-8999
email: aaatrans@cgmailbox.com
Aastro Transmission
James Marshall
8150 E 22nd St
Tucson, AZ 85710-8554
County: Pima
Phone: (520) 298-1103
Aastro Transmission
James Marshall
5302 E Speedway
Tucson, AZ 85712
Phone: (520) 325-5500
Aastro Transmission
James Marshall
4443 W Ina Rd
Tucson, AZ 85741-2207
County: Pima
Phone: (520) 744-0655
Aastro Transmission
James Marshall
1401 W Valencia Rd
Tucson, AZ 85746-6036
County: Pima
Phone: (520) 295-8878
Action Transmission
Don Oran
2190 Hwy 95
Bullhead City, AZ 86442-6001
County: Mohave
Phone: (928) 758-4455
email: actiontrans@citlink.net
Website: http://www.atra.com/~action
Adolph's Automatic Transmission
Adolph Determann
6626 W Glendale Ave
Glendale, AZ 85301-2344
County: Maricopa
Phone: (623) 937-2911
American Five-Star Transmission
Eric J. Ali
2070 E Apache Blvd
Tempe, AZ 85281-4849
County: Maricopa
Phone: (480) 966-8181
Atlas Transmission
Tony Izzo
2380 W Wetmore Rd
Tucson, AZ 85705
County: Pima
Phone: (520) 293-4090
email: tonyizzo@transmissiontucson.com
Website: http://www.transmissiontucson.com
Automatic Transmission Exchange Inc
Philip R. Briggs
4120 E Washington St
Phoenix, AZ 85034-1892
County: Maricopa
Phone: (602) 275-9571
email: atexchange@juno.com
Automatic Transmission Rebuilders
Tim Prentice
124 E Beale St
Kingman, AZ 86401-5828
County: Mohave
Phone: (928) 753-3121
email: atr@frontiernet.net
B & K Transmission Ctr
William Hutto
4657 E 1st St
Tucson, AZ 85711-1101
County: Pima
Phone: (520) 795-9823
Cecil's Garage
Scott Adams
2814 S 1st Ave
Safford, AZ 85546-2218
County: Graham
Phone: (520) 428-2502
Certified Transmissions Inc
Michael Pfeiffer
1089 Iron Springs Rd
Prescott, AZ 86305-1621
County: Yavapai
Phone: (928) 778-2231
email: certified@cableone.net
Website: http://www.atra.com/~certifiedtransmissions/
Denny's Transmission
Michael VanLoo
3902 S Central Ave
Phoenix, AZ 85040-1018
County: Maricopa
Phone: (602) 268-0663
Michael VanLoo
12614 N Cave Creek Rd Ste 102
Phoenix, AZ 85022-5860
County: Maricopa
Phone: (602) 788-1104
Desert Transmission
Jim Szafranski
1009 Grand Ave
Phoenix, AZ 85007-2513
County: Maricopa
Phone: (602) 252-5261
email: dtenterprise@aol.com
George's Automatic Transmission
George Banghart
3720 E Hardy Dr
Tucson, AZ 85716-1497
County: Pima
Phone: (520) 323-1250
Grant's Transmission
Fred Hammer
215 W Broadway Rd
Phoenix, AZ 85041-2494
County: Maricopa
Phone: (602) 276-9151
Hometown Trans & Auto Rpr
Bruce Napier
935 Haining St
Prescott, AZ 86305-1615
County: Yavapai
Phone: (928) 778-4663
email: hometowntrans@yahoo.com
Interstate Transmission
Bud Gibbons
1680 Acoma Blvd W Ste E
Lake Havasu City, AZ 86403-2812
County: Mohave
Phone: (928) 855-0161
Kermit's Certified Transm
Kermit Glenn
2425 Northern Ave
Kingman, AZ 86401-2601
County: Mohave
Phone: (928) 757-1020
P & D Transmissions & Differentials Inc
Paul J. Henry, Jr.
8708 W Thunderbird Rd Ste 3
Peoria, AZ 85301
Phone: (623) 979-3334
email: panddtrans@aol.com
Performance Transmission Inc
Dillard Edwards
7740 N 68th Ave #1
Glendale, AZ 85303-1326
County: Maricopa
Phone: (623) 931-8078
email: performt@earthlink.net
Website: http://www.performancetransmission.com
Quality Transmission Care Inc
James Bohlen
112 N 5th St
Sierra Vista, AZ 85635-1902
County: Cochise
Phone: (520) 458-1147
email: transman@theriver.com
Quality Transmission Svc Inc
Bob Jones
221 S McClintock Dr
Tempe, AZ 85281-2211
County: Maricopa
Phone: (480) 966-5800
email: bobjones@quality-trans.com
Website: http://www.quality-trans.com
RB's Transm & Classics
Robert & Karen Barnes
1020 Empire Dr
Lake Havasu City, AZ 86403-2429
County: Mohave
Phone: (928) 854-8806
email: transdoc@c-yaa.com
Ryan's Transmission
Neil Powalisz
1590 Industrial Blvd #B
Phone: (928) 854-1999
email: LHTRANSMAN@yahoo.com
Southwest Transmission
Russ Adams
741 E Deuce Of Clubs
Show Low, AZ 85901-4925
County: Navajo
Phone: (928) 537-1122
email: southwesttrans@citlink.net
Russ Adams
615 Navajo Blvd
Holbrook, AZ 86025-2642
County: Navajo
Phone: (520) 524-2300
Russ Adams
1318 E White Mountain Blvd
Pinetop, AZ 85935-7020
County: Navajo
Phone: (520) 367-1520
State To State Transmissions
Stephen Chen
2540 E Bell Rd
Phoenix, AZ 85032-2414
County: Maricopa
Phone: (602) 971-1962
Website: http://www.statetostate.com
Sun Transmission
Norman Lane
2330 W Glendale Ave
Phoenix, AZ 85021-7671
County: Maricopa
Phone: (602) 864-1718
Sun Transmission
Norman Lane
8135 NW Grand Ave
Peoria, AZ 85345-6567
County: Maricopa
Phone: (623) 979-0318
email: suntransmission@aol.com
Sun West Transm & Radiators
Jerry Davidson/ Greg Davidson
6116 W Northern Ave
Glendale, AZ 85301-1227
County: Maricopa
Phone: (623) 842-0806
Team Ramco Transm, Converters & Parts
David Sharrar
4701 E Gila Ridge Rd
Yuma, AZ 85365-7560
County: Yuma
Phone: (928) 344-5360
email: teamramco@beamspeed.net
Thrifty Transmissions
Roopa Syed / Delta Enterprises
2855 S Alma School Rd #107
Mesa, AZ 85210-4030
County: Maricopa
Phone: (480) 820-6100
Trans-Matic Transmissions
Randy Montgomery
253 W University Dr
Mesa, AZ 85201-5819
County: Maricopa
Phone: (480) 834-7799
email: aztransmatic@aol.com
Transmission Outlet
John Starits
1050 S Euclid Ave
Tucson, AZ 85719-6630
County: Pima
Phone: (520) 882-8210
email: bossjs@aol.com
Website: http://www.atra.com/~transoutlet
Transmission Unlimited Inc
David Wolfe
1537 S Craycroft Rd #131
Tucson, AZ 85711-7210
County: Pima
Phone: (520) 790-6720
Transmissions Plus
Keith Lute
1291 S 5th Ave
Yuma, AZ 85364-4634
County: Yuma
Phone: (928) 539-5277
Tri-City Transmission Service Inc
Michael Young / Leon Bouchy
203 N McClintock Dr
Tempe, AZ 85281-2208
County: Maricopa
Phone: (480) 968-5062
email: tricity@tricitytrans.com
Website: http://www.tricitytrans.com
V and C Transmissions
Juan Carlos Raya
4035 N 83rd Ave
Phoenix, AZ 85033
Phone: (623) 845-8131
email: juanraya@msn.com
*If the member is an ATRA certified rebuilder, diagnostician, or R&R technician their record will display with a certification logo (provided by ATRA) next to the name of the shop.
Hi, Jim,
Drew,
Jerry Chase
4570 E Irvington Rd
County: Pima
AAA Transmission
Martin Johnson
1146 E Jimmie Kerr
County: Pinal
Aastro Transmission
James Marshall
8150 E 22nd St
County: Pima
Aastro Transmission
James Marshall
5302 E Speedway
Tucson, AZ 85712
Aastro Transmission
James Marshall
4443 W Ina Rd
County: Pima
Aastro Transmission
James Marshall
1401 W Valencia Rd
County: Pima
Action Transmission
Don Oran
2190 Hwy 95
County: Mohave
Adolph Determann
6626 W Glendale Ave
County: Maricopa
Eric J. Ali
2070 E Apache Blvd
County: Maricopa
Atlas Transmission
Tony Izzo
2380 W Wetmore Rd
Tucson, AZ 85705
County: Pima
Philip R. Briggs
County: Maricopa
Tim Prentice
124 E Beale St
County: Mohave
William Hutto
4657 E 1st St
County: Pima
Cecil's Garage
Scott Adams
2814 S 1st Ave
County: Graham
Michael Pfeiffer
County: Yavapai
Michael VanLoo
3902 S Central Ave
County: Maricopa
Michael VanLoo
County: Maricopa
Desert Transmission
Jim Szafranski
1009 Grand Ave
County: Maricopa
George Banghart
3720 E Hardy Dr
County: Pima
Fred Hammer
215 W Broadway Rd
County: Maricopa
Bruce Napier
935 Haining St
County: Yavapai
Bud Gibbons
County: Mohave
Kermit Glenn
2425 Northern Ave
County: Mohave
Paul J. Henry, Jr.
Peoria, AZ 85301
Dillard Edwards
7740 N 68th Ave #1
County: Maricopa
James Bohlen
112 N 5th St
County: Cochise
Bob Jones
221 S McClintock Dr
County: Maricopa
1020 Empire Dr
County: Mohave
Ryan's Transmission
Neil Powalisz
Russ Adams
County: Navajo
Russ Adams
615 Navajo Blvd
County: Navajo
Russ Adams
County: Navajo
Stephen Chen
2540 E Bell Rd
County: Maricopa
Sun Transmission
Norman Lane
2330 W Glendale Ave
County: Maricopa
Sun Transmission
Norman Lane
8135 NW Grand Ave
County: Maricopa
6116 W Northern Ave
County: Maricopa
David Sharrar
Yuma, AZ 85365-7560
County: Yuma
Mesa, AZ 85210-4030
County: Maricopa
Randy Montgomery
253 W University Dr
Mesa, AZ 85201-5819
County: Maricopa
Transmission Outlet
John Starits
1050 S Euclid Ave
County: Pima
David Wolfe
County: Pima
Transmissions Plus
Keith Lute
1291 S 5th Ave
Yuma, AZ 85364-4634
County: Yuma
203 N McClintock Dr
County: Maricopa
Juan Carlos Raya
4035 N 83rd Ave
Phoenix, AZ 85033
Damn!
I wish I knew about your stuff back when I had my transmission out of my car, being rebuilt!
I would have sent it to you...
Oh well.
When you offer the valve body mod as a kit, I'll be happy to buy one.
Oh well.
Hello Steve,
Thank you for taking the time to explain all of this. I understand your need to focus on business. Without it you could not continue to offer your services.
My car has the original transmission and converter. It launches with slight wheel spin up to 25 MPH and then gains traction dropping the RPM from 3000 to 2200 in 1st. A big increase in stall speed would probably be a bad thing, perhaps ~2500 to 3000 RPM. Peak torque comes at about 4500 - 5000 RPM with the GT cams indexed as they are. Yes, I changed the S4 cams out with GT cams. Lots of high RPM torque but nothing below 4000. Perfect for the track but not ideal for daily driving. Peak HP is at 6200 RPM = 336 RWHP.
I will run a few more tests and try to identify the stall speed per your instructions. I believe that my car could definitely benefit from a higher stall speed.
Sincerely,
Steve Pappin
Sincerely,
Steve Pappin
4th Gear
Steve,
I wrote to you shortly after you posted the 1st gear start valve body "kit" originally. I am still interested, whenever you have one available as a kit rather than full rebuild. Please put/keep my name on the list.
Gary Knox ( e-mail is: kittyandgary@ccis.net )
An outfit called bergwerks made first gear start modules for MB 722.3 transmissions, but I don't think they're in business anymore.
This fellow, who's active on Benzworld R107 made his own first gear start module. I expect that as the 928 has the same transmission , it will probably work for the 928.
Good luck!
Good luck!
I think to do it properly you need to modify the valve body. I was hoping for GB to chime in.
How much would this be worth? I know the difference in my car when starting off in 2nd position (first gear to redline or "row to shift") would be worth quite a lot to me.
I'm pretty sure the MB R107 ('70's and 80's 450/380/560 SL's) has a different transmission than the 4 speed automatic in the 928 (perhaps MB did put a 4 speed in the later 560's). I'm 99% sure the 928 trans is the same as in the MB 126 chassis. (80's 560 SEL, 560 SEC, etc.), which has a 4 speed automatic, and more powerful engines. I've had both of these MB models, and 4 928 autos. The early 107 chassis had a 3 speed auto.
Gary-
Gary-
For Mercedes, the 3 speed and 4 speed cars drove pretty much the same as the first gear on a 3 speed car is more like a first and second gear combined (I can get up to almost 70mph in my 6.9 when in kick down before it changes into second gear), and the 4 speeds came standard with a second gear start for US cars.
The only different between the earlier 380/500 and the 420/560 transmission is that the later cars used CIS-E injection instead of CIS. Because of this, the later transmissions have a cut out on the bell housing for a pick up sensor that reads marking on the flywheel, to feed information back to the ignition unit (EZL).
This part has nothing to do with 928's as they have a completely different fuel injection system. The valve bodies should be the same and the 1st gear start deal is a pretty common modification for performance minded SEC and SL owners.
If you're looking for a first gear start valve body, you can probably find one on the Mercedes benz forums. There was a fellow on the 500E forum that was selling two not so long ago.
The bergwerks 1st gear start module that I mentioned earlier replicated a feature that was standard on 86+ Mercedes Benz models sold outside North America. My European spec 560SEC has a Sport/Economy switch that allows you to either start in first or second gear. This feature was not available on US cars.
I hope this helps.
You need the 722.3 for the 4 speed 928's and 722.0 for the 3 speed cars.
The 722 transmission is an MB transmission and applies to every Automatic tranny built by MB since about 1970.
The .1, .4, .5, .6 and .9's have nothing to do with 928's.
