debris found in 5spd transmission
Archive Gatekeeper
Gear selectror on all manual gearboxes should always be left into either gear closest to neutral position
[stupid question mode]
So for an 85-95, does that mean 2nd or 3rd gear? I leave mine in neutral with the parking brake on, makes it easier to roll it back and forth as needed in my tight garage. [/stupid question mode]
For '85-86 it should mean between 4/5 as that flat spring in those boxes only works into one direction thightening further away selector goes from 4/5. In many cases spring is so weak that selector will remain in 2/3 area but according to all I have read and seen this is not the way factory intented it to be.
Same thing goes with '78-84 boxes too, 4/5 is where those coil springs and gravity wants to push selector. '78-81 used just gravity to take selector from 2/3 to 4/5, '82-84 have one extra coil spring to help on this. Some people have turned this springs action around and created 2/3 centering setup. This is only temperary solution as two springs are fighting against each other and one is going to loose this fight eventually. During this duel neutral position will start to move left or right from 2/3 depending on which spring is winning.
Flat spring and few other parts were changed in '87 MY specifically to get selector to remain in 2/3 area. Its possible to retrofit this setup to '85-86 quite easily. All it takes to do it right is about half dozen parts including transmission cover. Worst part is that this makes flat spring problem only marginally better. In '85-86 setup spring is pushed more due to only one direction away from stop action it has and this will probably kill it sooner than later '87-95 version dies. '82-84 is probably safest setup but even it is not immune to this stuff falls between gears and kills entire gearbox syndrome.
In reality it would be better to engineer entirely new setup to do both side to side action and reverse gear lock mechanism. This is most likely too much work for most of us. I'll rather spend that effort on 6 speed conversion.
erkka, it seems as if replacing the now broken spring might be simply asking for more trouble later - and potentialy a total loss of the transmission. how bad will it be not to replace the spring?
Have driven few were spring was in pieces like you have. Really hated it but its drivable without any real problems.
While gearbox is out its good time to change selector, input and drive shaft seals. If they are old its very likely at least one of them will leak soon anyway. There is very little point on buying these seals individually as total set should cost under $100. This is just 1/2 price of flat spring. IIRR reverse gear lock spring is NLA.
the more i think about it the more i am reluctant to want to put a spring back in that i know will fail and potentialy destroy the gearbox. i cant see myself pulling the box and replacing the spring every five years as preventative maintenance... but i dont know if the shift will drive me crazy without it???
