View Poll Results: Laso Water Pump Fine or Failed?
Fine up to five years after fitting
0
0%
Failed over five years
0
0%
Voters: 9. You may not vote on this poll
Laso Water Pump Failure Poll
I was surprised at the result of the Anchor Hydraulic poll, I had assumed there would be a significant number of failures - Not according to the poll results.
So I thought it would be worth doing the same for Laso Water Pumps which have also recieved bad press on the forum - but is it justified?
Please don't respond to the poll unless you have fitted a Laso Water Pump.
Replacement pump is +70k kms old, running fine, no idea of make PO had it done.
I did look at it as close as you can when doing the tbelt job.........it spun well, no noise and no lateral movement.
Its still in there and rockin'
