928 Forum 1978-1995
Sponsored by: 928 Specialists
Dad's slave bleed method might work...
Old 09-29-2010, 03:36 AM
jheis
jheis's Avatar
Here's a video using a different method to achieve the same result (reverse bleeding the clutch). Enjoy.
http://www.youtube.com/watch?v=wdf--...eature=related
James
Old 09-29-2010, 07:52 AM
Ad0911
Ad0911's Avatar
I use a contraption called "Easybleed" for this type of job. It uses air pressure from the tyre to puch up the brake fluid. No pumping required. On man job.
Old 09-29-2010, 08:06 AM
Marine Blue
Marine Blue's Avatar
What a great idea.
Only issue I would see is any drips from the hose connecting the brake to the slave after removal.
Assuming your in the garage, why not connect the pressure bleeder to the slave nipple instead?
Old 09-29-2010, 09:40 AM
jwillman
jwillman's Avatar
Originally Posted by Marine Blue
What a great idea.
I have read that method here somewhere and heard it works well. Only down side is making sure the additional fluid does n ot overflow at reservoir.
The brake bleeder to clutch bleeder eliminates that issue. Easier to add a bit of fluid lost in filling the connecting line than getting excess fluid out or cleaning up. I will try this method this weekend after replacing the upper release are ball socket
Old 09-29-2010, 01:18 PM
928FIXER
928FIXER's Avatar
Been bleeding clutch hydraulics from the bottom up for over 20 years,and not only 928's.I do almost every car that I'm working on clutchs hydaulics that way.
Old 09-29-2010, 01:23 PM
Landseer
Landseer's Avatar
Fixer, any issues with removing air from the clutch master? Or is it just me?
Old 09-29-2010, 04:08 PM
karl ruiter
karl ruiter's Avatar
Its a cool idea, I think I will try it next time. But for me the best thing is to do the burp. Works the first time, every time. Takes 2 minutes.
Old 09-29-2010, 05:09 PM
jwillman
jwillman's Avatar
Karl,
Are you talking at the slave by depressing the plunger slowly or at the master by pulling the internals out through the front?
Quick Reply: Dad's slave bleed method might work...
