Chips for 82?
I just read the chip post re: ebay and it made me wonder... I chipped my 87's and could tell an immediate difference. Actually I chipped the auto with a clone for about $50.00 and it was great. I got the same clone for the 5 speed and when I opened it up, it already had the AutoThority chips, so...
My question is.. I have never seen a chip or chips offered for the 82 and was wondering if this is just not popular enough or if it can't be done - easily, or if there is some other reason.
Inquiring, uninformed minds want to know.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Rod
Rod
Administrator - "Tyson"
A lot of what those chips do is change timing to increase HP.
On your 82, just loosen up the 13mm bolt on the distributor, and rotate
Inventor
L-Jet fuels quite well through the whole rpm range, if all the sensors all working, even with mods, without a AFPR. If it doesn't fuel properly after mods, it's likely a problem with the mods.
