928 Forum 1978-1995
Sponsored by: 928 Specialists
Jingling transmission?
Old 05-29-2003, 09:09 PM
Steve Cattaneo
Steve Cattaneo's Avatar
Post
Jessa,
From a stop with the engine running disengage the clutch if the noise from the rear disappears, possibilities are torque tube or transmission.
Toejam,
A clinking noise in one gear could be a broken tooth on that gear, drain the oil and see what comes out.
Good luck to all
Old 05-30-2003, 03:11 AM
Toejam
Toejam's Avatar
Post
Steve, you actually bring me to another question I was going to ask... how are you supposed to get to the fill plug on the top of the transmission? I've heard of people snaking funnels through the battery case to fill the transmission, but I dont see a way possible to get up around to take the plug out (If I knew exactly where it was, that might help, too ). What's the trick?
Old 05-30-2003, 09:50 AM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Post
The fill plug on the five-speed is the top plug on the rear face of the differential.
ALWAYS take the fill (top) plug out before taking the drain (bottom) plug out!
Old 05-30-2003, 11:01 AM
AO
Supercharged
AO's Avatar
Post
Toejam-
As Wally says take out the fill first because that way you are sure you can fill it back up. Don't ask how I know! (Doh!)
But the way Ifilled it up was to use a pump style bottle with a length of hose attached. Then I just pumped for about 15 minutes and the job was done! Anoter way I have heard of is using an access plug in the trunk or battery box and snaking a hose through there and then using gravity to fill it up.
Good luck.
Old 05-31-2003, 02:17 AM
karl ruiter
karl ruiter's Avatar
Post
This is not inside the car, but it might be a possibility anyhow. I think there are some little metal shims between the tranny and the mount. If the tranny mount bolts were not tight they might jingle. I had a 914 that jingled for that reason once.
Old 05-31-2003, 09:18 AM
Nachtmeister
Nachtmeister's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Toejam:
<strong>I have a similar scenario. In my car, I get a weird jingling/clinking/tapping/ticking (use your imagination )[...]</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">I actually did use my imagination and now I'm hearing it too...
Once upon a midnight dreary, while I pondered weak and weary,
Over many a quaint and curious volume of forgotten lore,
While I nodded, nearly napping, suddenly there came a tapping,
As of some one gently rapping, rapping at my chamber door.
taken from "The Raven" by E.A.Poe
These sounds can drive you nuts. <img border="0" alt="[ouch]" title="" src="graemlins/c.gif" />
Quick Reply: Jingling transmission?
