Need 2 radiator clips that hold small dia coolant hose
I am looking for the two clips/holders that retain the small dia. coolant hose that runs from the top of the radiator to the coolant reservoir. I purchased a used radiator but it came without the clips. I threw away the old damaged radiator without removing these same clips. If anyone has these laying around, I will be happy to work out terms.
Big AL from VA
84 928S2 Euro twin distributor monster
Big AL from VA
I'm just using a small hose clamp on mine. I installed an earlier model radiator after the Devek went kaput. I did notice last night that it was not the best fit, but tightened it up and it seems to work.
Arent these part of the rad itself or part of the metal strip with the rubber seal attached that sits on top of the rad? (I'm at work and having a hard time picturing this)
The reason for my speculation above is that RHD 928s also have clips but they aren't used because that coolant line runs straight back to the reservoir not across the top of the rad.
