928 Forum 1978-1995
Sponsored by: 928 Specialists
Finally bought a 928 - what now? - UPDATE
Old 10-29-2007, 04:33 PM
  #31
Hilton
Hilton's Avatar
Originally Posted by michaelathome
2) dash illumination NOP
3) remote hatch release NOP
Both of those are the same fuse IIRC.
Michael
Here's the fuses and relays chart..
https://www.928gt.com/t-8788fuse.aspx
Looks from the chart like, as with my '89, the interior lights, hatch and tacho signal are all on the same fuse - so if the tachometer isn't working then michael's right.
Old 10-29-2007, 08:19 PM
  #32
sendarius
sendarius's Avatar
Darn, the tacho is working fine.
I have a "clean CE" task on my list, and I'm hoping that I find a fuse or two loose, corroded, or blown.
Old 10-29-2007, 08:49 PM
  #33
JPTL
JPTL's Avatar
After you get the critical stuff done (or while you're in between big jobs) check the "C" clips that retain the pop-up light linkage @ the motor (driver's side).
They're notoirious for popping off over time, and if both go, the motor arm will eventually work its way off the linkage and drive itself into the radiator the next time that you turn on the headlights.
I believe that this is unique to Sharks, so it's easy to miss.
Here's a link w/more details: https://rennlist.com/forums/928-forum/261071-warning-to-all-928-owners-check-your-headlight-clips-upgrade-solution-post-119-a.html
Old 10-29-2007, 09:30 PM
  #34
sendarius
sendarius's Avatar
Man, oh man, THAT is the reason that Rennlst is so good. A "feature" burns somebody, and this forum provides a mechanism by which other enthusiasts avoid being burned.
I LOVE RENNLIST. Thank-you JD! (and JPTL)
Quick Reply: Finally bought a 928 - what now? - UPDATE
