Alternator cooling hose......?
On models with s spoilers where does this hose go?
Installing spoiler now and wondering what to do with hose, it has a wire going to it (sensor?). Someone with a factory manual may be able to tell me the routing differance between the 2-cars one without spoiler ala early car, and S models with front spoiler. Thanks in advance
Man on a mission........ <img src="graemlins/c.gif" border="0" alt="[ouch]" />
No difference - the laternator cooling hose runs from the alternator down to the bottom of the front fender, and then up inside the front fender under the headlamp. It actually attaches to, and makes a "U" bend on, the fender liner that is just in front of the tire.
WYAIT, clean and check the outside air temp sensor and its connections carefully, as this is one of the common problem areas for the HVAC control system.
