Chips. What aftermarket chips are people using?
Chronic Tool Dropper
Tom wrote:
<STRONG>What are the extra horse power ratings and the cost? I am looking at a 928S4. </STRONG>
I have the Autothority chipset in my '89 S4. The peak horsepower number probably hasn't changed much. The most noticeable improvement for me is in low-midrange torque, and the sharper throttle response that's the result of a little extra timing advance.
Downsides:
1) You MUST use a good grade premium, especially in hot weather. I end up using some 104+ on summer days when the AC is on to control detonation. I have a rising-rate adjustable fuel press regulator to go in there one of these days that may help this a bit.
2) The cost. In my opinion, there are better places to find the power. If you don't mind the noise (again, my opinion...) then the RMB would be a much better choice.
3) The car failed California smog on high NOX. NOX is a function of combustion temps too high, typicaly the result of timing advance or a failed cat. I popped the original chips back in, and retested OK. The difference isn't a lot, but was enough to get through the test.
All in all, knowing what I know now after a couple years with them, I probably wouldn't bother with this modification.
Bob
'89 S4, stock again.
Originally posted by dr bob:
<STRONG>
snip
snip
</STRONG>
<STRONG>
snip
snip
</STRONG>
Thanks.
