Floppy axle (verify torque specs.)
Hmmm, a few minutes ago, about a half mile from home as I very slowly turned a corner, there was a loud clunk, followed by some nasty sounding metal pounding and no forward motion.
I got it home and found that one of the axles had come loose from the differential. It bent one bolt, no other harm, since I had an extra set of axles and bolts, but... the workshop manual
only indicates 26ftlb or 22Nm for the torque on these 6 bolts. That seems awfully low, but I did it. If someone knows that these should be tighter, please let me know. I was lucky it was not at 70 mph or I could have done some real damage.
Rod
only indicates 26ftlb or 22Nm for the torque on these 6 bolts. That seems awfully low, but I did it. If someone knows that these should be tighter, please let me know. I was lucky it was not at 70 mph or I could have done some real damage.Thanks
Rod
Rod, Your looking at the wrong torque!!! Per my tech Spec Book it should be 81nm or 60 ft lbs. I just swapped my rear axles last week and that's what I torqued mine to.
Jim Mayzurk
93 GTS 5-spd
Jim Mayzurk
93 GTS 5-spd
Driver side on the rear. I think I was very lucky that it didn't tear up anything. A high speed spinning axle, completely loose from the differential, flopping around as the wheel turned, could have been very bad.
Rod
Rod
I retorqued both sides last night and they both needed it. I'll keep an eye on them and if they loosen, I'll try locktite and see if that helps.
It was a bit disconcerting, I have to admit. On the way home, behind my son in the truck, I was wondering if I was going to have to get a late model 5 speed to replace a broken one.
Rod
Rod
I know this is an old post but have been thinking about this for a while anyway...
I also own a 914 and they have a Schnorr washer (ribbed washer) that is supposed to help keep the bolts tight. I was a bit surprised that there weren't any on the 928 as the guys on the 914 forum make a big deal about putting new ones on each time the axle bolts are removed.
Can anyone think of a disadvantage to using them on the 928? I was thinking of adding them before bolting up my tranny.
No disadvantage that I'm aware of. The few 928's Ive done axle work on (only S4's and GTS's) also have a "link" washer assembly that goes to the next bolt. So you have three links for the six bolts. I've never seen these come loose when torqued correctly, but your washers will also work. But I think it's an either/or situation, not both.
