928 Forum 1978-1995
Sponsored by: 928 Specialists
Coolant hose burst on freeway (or.. Why's it raining green?)
Old 10-18-2007, 01:43 AM
3000teeth
3000teeth's Avatar
Originally Posted by SharkSkin
Wow, that "pop" sounds strange. Keeping my fingers crossed for you...
I agree --sounded like a heavy gauge balloon exploding. Weird!
Thx for the support.
Old 10-18-2007, 01:45 AM
3000teeth
3000teeth's Avatar
Originally Posted by nosnow
Sorry to hear you are having more problems.
I think you idle problem may be related to a vacuum leak or a poor connection with the MAF or ignition control unit. If the engine isn't missing I doubt you will find a problem with either the distributor or plugs. just my .02
Dr. Bob, thanks for correcting me. I was thinking that the flow from the radiator would show up as it does in VW tanks.
Thanks Paul --I'll poke around and see if I may have knocked something loose and pray that this won't be another needle in the haystack troubleshooting session.
Old 10-29-2007, 05:41 PM
3000teeth
3000teeth's Avatar
So I believe I've nailed down the cause of my hose bursting: faulty radiator cap
Thanks Rog, for reminding me of this cause/effect relationship --I think the last time this happened to me it was on a girlfriend's Audi Fox back in 1987 --wow, 20 years ago.
Old 11-08-2007, 01:16 AM
carguyhere2
carguyhere2's Avatar
Originally Posted by 3000teeth
You were right-on about how much water it needed --thx. I'll also check out the Redline.
2nd on the Redline, it really works
Old 04-12-2008, 04:05 PM
3000teeth
3000teeth's Avatar
Update:
So I'm pretty sure I figured out the problem.
It turns out the MAF is cracked (was when I bought the car). The top crossbar where the air intake connects is completely broken off --I knew about this, but didn't realize what I was dealing with --looks like the MAF is cracked completely down the side, and I'm guessing when the hose burst and all that coolant hit it, it either cracked more or something else went haywire.
Now to replace it. Anything I should know before I start?
Quick Reply: Coolant hose burst on freeway (or.. Why's it raining green?)
