Interior LED Changeover (uhm...Looooong)
#106
IIRC, some of the bulbs on earlier cars were soldered in.
I seem to remember some posts on this topic (bulbs in earlier cars); if anyone could link to those here, that would be nice.
#108
I could be wrong - as I've never owned an early car, and I'm going just from memory of reading rennlist posts. A search here for "BA9 shifter" might answer whether I'm right.
#110
I just tried the main link at http://www.ed.scherer.name/Porsche_9...0to%20LEDs.pdf and it was OK. What exactly are you seeing?
Anybody else having a problem with that link?
#111
All I get is just a blank white screen. My computer recently upgraded itself to IE11 and it has been quirky. So, if you say it is there, then maybe it is one of those undocumented features of IE11. I'll play with the IE11 settings some more.
Thanks,
Thanks,
#112
Greg, you could also try (in IE11) right-clicking the link and "Save As..." to a file on your computer. Then double-click that file in Windows Explorer to open it up in Adobe Reader (or whatever other PDF reader you might have established for .pdf files).
#113
I read the initial post but not the follow-ups so this may have been discussed?
For the interior and under hood festoon bulbs it seems there are two different lengths.
Anyone know what they are and how many of each?
There are a total of 8: 2 doors, 1 overhead dome, 1 rear hatch, 1 glove box, 1 courtesy light in pax footwell (GTS) 1 overhead reading light between visors, 1 under hood light.
Thanks.
Thanks.
#114
Thanks.
Thanks.
#115
Thanks, Ed - that write-up is a thing of beauty. I need to add it to the FAQ if it's not already there.
The GTS under hood light is indeed an old fashion festoon bulb. May just leave it stock for now.
In Keith's write-up he recommends a brighter bulb for the forward 'map light' located between the front visors. Did you use a different type for that one?
I'm wondering why you chose the narrow beam type for the overhead hatch, rear hatch and CEL panel locations?
#116
I believe the recommendations in the "Courtesy Lighting" section (near the end) of Converting Porsche 928 Interior Lighting to LEDs are all valid except the under hood bulb changed sometime after the '90 MY ('91, I think); '90 doesn't use a festoon for the under hood lamp. There's also a complication with that one. See the threads LED under hood lighting and New hood switch, strange light behaviour?. Looks like you'll need a 220 Ω load resistor in parallel with that under hoold LED lamp.
#117
#119
Cottage Industry Sponsor
IIRC, the original interior festoon bulbs were 36mm long. However, in that length there were no really bright LED replacements. So we used the 38mm long version, which was also available in different colors. It was a bit harder to install the longer bulbs, but one could shoehorn them in without too much effort. And because they don't create as much head as the original bulbs, the fixtures never buckled.
