928 Forum 1978-1995
Sponsored by: 928 Specialists
Sagging fuel gauge
Old 06-01-2002, 10:11 AM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Exclamation
Our fuel pumps are lubricated by the gas they pump. You will shorten the life of the fuel pump by running out of gas.
As to the low volts reading: There is an adjustment pot on the side of the voltmeter. Put a multimeter to the battery, start the car and adjust the pot 'til you are in synch with the multimeter. I did this before my trip to SITM and it worked great. But, it took a bit of time getting used to the gauge reading higher.
Good luck.
Quick Reply: Sagging fuel gauge
