928 Forum 1978-1995
Sponsored by: 928 Specialists
Fabrication help needed
Old Apr 20, 2003 | 11:33 PM
Koenig-Specials 928's Avatar
Koenig-Specials 928
Question Fabrication help needed
I've fashioned a piece of aluminium to replace the
rubber accelerator pedal & footrest in my '89. Now what do I have to do to give it the 'brushed look'?
Thanks for any advise.
Hessan
Old Apr 20, 2003 | 11:49 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Post
ssuming that the surface is smooth after your handiwork, try a Scotch-Brite scrubbing pad. These come from Home Depot stores and the like, in different "grits" for different finish quality. Once you have the look you want, seal the finish with a clear acrylic to preserve it.
Remembner that the aluminum will continue to oxidize unless you seal it or anodize it. Finger prints are acidic, so the last handling steps prior to painting should include gloves.
Anodizing is a relatively inexpensive process, and usually includes the prep. That prep can easily include adding the satin finish you desire. If this is a part you will be showing off, this is the way to go.
Good luck!
Old Apr 21, 2003 | 12:21 AM
Koenig-Specials 928
Post
Thanks Bob. You have given me all of the information that I needed.
Cheers,
hessan
