928 Forum 1978-1995
Sponsored by: 928 Specialists
Hatch Adjustment
Old Apr 20, 2003 | 11:00 PM
PatrickP's Avatar
PatrickP
Question Hatch Adjustment
Seems to me that I read a post about adjusting the rear hatch somewhere on the board. Mine is a little out of alignment and if adjusting is not too complicated I would like to give it a shot. If anyone knows of a post or could give me the thumbnail I would be grateful. Also wondering about the difficulty level: six pack, twelve pack ... case? <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Old Apr 20, 2003 | 11:13 PM
Mark's Avatar
Mark
Post
Is it the whole hatch (12 pack) or just the latch (pony bottle)?
Old Apr 20, 2003 | 11:51 PM
TAREK's Avatar
TAREK
Post
Dave Roberts suggested that I use pennies as shims to adjust the alignment on mine and it worked like a charm
Old Apr 21, 2003 | 12:04 AM
Mark's Avatar
Mark
Post
I used some thick plastic and cut a shim to fit the part on the hatch...also - you may be able to re-position the receptacle for the piece on the hatch to better 'catch'
Old Apr 21, 2003 | 09:48 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
Post
There are seveal kinds of misalignment, as you might have gathered from the answers that you have received.
You will get more meaningful answers if you define the misalignment a little more fully.
Old Apr 21, 2003 | 12:56 PM
BrianG's Avatar
BrianG
Post
I too am interested in the "alignment" issue. I plan to replace my whole hatch with the "S4" version to accommodate the wing and eliminate the spoiler. Comments and instructions would be appreciated.
Old Apr 22, 2003 | 11:04 PM
PatrickP's Avatar
PatrickP
Post
Thanks for all of the input, guys. To answer Wally's question: My rear hatch appears "off" by about an eigth of an inch. To be more specific, it is as if it has "slipped" straight back just enough to where the latch release will not release the hatch and the hatch does not line up with the rest of the body. If someone could tell me how to do it, and assuming you are still wondering what I am talking about, I could post a picture. Maybe a note to Randy in that regard is in order. Thanks again.
Old Apr 23, 2003 | 12:29 AM
Greg86andahalf's Avatar
Greg86andahalf
Post
I'm going to keep an eye in this thread. My hatch has slipped the same way and I can see no way short of removing and modifying the hinges to get it right. There is access to the hinge bolts under two caps inside on the headliner, but not enough play in the hinge mounting to make a difference.
I hope someone comes up with an answer.
Greg
