Race Engine Built
It seems that drilling the crank is the way to go forward. I have found several engine building shops in the UK who can do it. I just did not feel like opening up what is a beautiful bottom end - it is only done 20k miles.
With regards to Bhp expectations - a stock GTS engine with bigger injectors, EZK and LH remap and cams, which are a half way house between S4 and GT, made 385Bhp on the crank. I would expect to see 400/410bhp on the crank with GT cams, 968 valves and proper headers from 928 International. I think I would go for 2.5" dual pipes all the way back...
Alex
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
shift at 6500rpm like me, and your motor will last forever,
no drilling, no accusump, no coolers, 6 full seasons of racing.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Alex, can you please list the rear wheel horsepower numbers instead? Quoting crank horsepower numbers means nothing since no one knows for sure which divisor was used against the numbers attained at the rear wheels from the chassis dyno. Unless of course, did you strap the block specifically onto an engine dyno and got a true number at the crank?
It is annoying, but I only have the crank numbers for this particular GTS-engined car. I wanted to quote comparable numbers - apples with apples so to say
Alex
P.S. What happens if you use DynaPack dyno - http://www.dynapackusa.com/index.htmwhat number do you quote then?Wheel hub horse power?
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I have 4 race cars and engines that beg to differ.
1. scots, already a full season of racing and running some of the faster times ever seen by a stock 928. (1:41s at laguna)
2. my old part euro, 2 full racing seasons and still running today
3. scots original 4.5 liter racer
4. my 4.7 original racer with 170,000miles and 3 years of obsessive track use.
I would be willing to bet the holbert car has nothing special done to it.
Mk
Mk
I hear you, but I don't want to mess around with the crank - I have to control my expenditure and if I am successful in reaching my goal of 410Bhp at the crank I would be happy.
Now, please tell me about the crank and the exhaust
Alex
Alex
What about the cams? If you have new cams or near new cams take them out and get Piper to grind an old set, I have a set of 86.5 cams which don't need grinding but if you found somebody that had a set that did need some work you will then open up the breathing. Talking of dyno numbers I will dyno my car soon, the dyno has been broken for a month now, I got some figures yesterday but I don't trust them I wish I could as I have a peak torque of 505 ft lbs at 4500 rpm, while the torque is fantastic in this engine, it aint that good. I hope to do 340 rwhp.
Alex we are lucky that we have the same brand of Dyno that has a tamper proof system (controlled ramp rate etc)that is supposed to give results from machine to machine with a variance of 1%
Also have you thought about buying a set of 968 pistons and selling your GTS block and fitting the 968 pistons in a good thick S4 block? You would get good money for the block and it would make you some extra capacity around 5.8 litres.
Good Luck
Greg
I have a goal of 400+bhp, which is achievable with valves, GT cams, exhaust and a JDS remap. This should be good to allow me to be competitive against the Aston Martin DB9 N24 in endurance racing - the N1 in class will always go to the ZakSpeed Viper... That is a beast, which even Mark A will have trouble with...
Alex
