What part is this
What part is this
I have a 79 that I am restoring. There is a part hanging on the cross brace under the hood that has a vac line or something attached to it also 2 elec. tabs at the bottom. What the heck is this for?
The part is your A/C idle air solenoid. When you turn on the A/C the solendoid opens a valve to let more idle air into the engine. This keeps the engine from stalling with the extra drag caused by the A/C compressor. BTW there should be two vacuum lines going to it.
Dennis
Dennis
Its the solenoid valve for the AC compressor "idle increase" when you turn on the AC.
Simul-post. Cool.
