Supercharger Belt
Great info if your in the USA , but unfortunately not if your 3000 miles east !
Captain Obvious
Super User
Super User
Uhhhh... Sorry I didn't notice that you are in the UK. In that case, contact a millwright (machine shop mechanic) and they will be able to tell you where to get the keys or better yet, call you local bearing supply store and they will be able to help you.
No Need to Worry Guys
She is up and running again![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
I knew i had the key as in a photo you could clearly see it, so i spent the morning looking for it, thanks to belly pans as thats where it was hiding.
pulley torqued and thread locked belt tensioned car running
Re check pulley and test drive
If you are thinking about supercharging just do it, its so cool![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Not fixed the powersteering leak yet, have removed ps belt, its a little heavy but not as bad as you think it would be
![order](https://rennlist.com/forums/graemlins/order.gif)
