Disconencting Bosch AMP connectors
Under the Lift
Oh, yeah, those connectors on the crank trigger, hall sensor and knock sensors are awfully fragile and fall apart if you look at them the wrong way. I haven't had the same problem with the FI or temp sensor plugs.
You need the clip unless you want to tie-wrap it on somehow. I bought some replacement AMP connectors on eBay for $2 each just to get the clip that came with them.
http://cgi.ebay.com/ebaymotors/ws/eB...m=290159815120
In this case the clip has a small "hand" on the end of each arm that prevents them from coming off and requires no plastic dab to retain them. So simple and so effective. Here's an illustration:
That's great value for the connectors!
Thanks everyone for all the accumulated wisdom and tips. Whenever I look back on these threads after doing a job I think how simple it seems in retrospect, and how clueless of me to have to ask. At the time though it's a great confidence-booster to have a few tips up my sleeve before the job and knowing some of you have been there done that!
