928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine runs, no forward or reverse motion
Old Sep 7, 2007 | 10:31 AM
hlj821's Avatar
hlj821
Default Engine runs, no forward or reverse motion
I was on a highway doing 70 mph when all of a sudden the tach needle went to redline and the engine raced with no acceleration. I could feel that car was coasting, so I exited at the next ramp and rolled to a stop at a parking lot. The engine sounds strong, but it will not move in forward or reverse. I heard a slight "chatter" coming from under the passenger side at a stoplight immediately before this. I was next to an older car and dismissed it as being from the car. Does this sound like Torque Tube failure? The car is an '86 Auto. Thanks.
Old Sep 7, 2007 | 10:55 AM
928drvr86.5's Avatar
928drvr86.5
Have a look at the bottom of the torque converter housing to see if the converter is spinning, motor running and tranny in park. If the converter is not spinning your TT is probably shot.
Old Sep 7, 2007 | 12:06 PM
Jim bailey - 928 International's Avatar
will the car roll if you push it with the trans in the park position ?
Old Sep 7, 2007 | 12:10 PM
linderpat's Avatar
linderpat
I just went thru a similar problem - broken half shaft in rear was my situation, but the symptoms are common to alot of things, some very bad
Old Sep 7, 2007 | 05:12 PM
hlj821's Avatar
hlj821
The car will not roll in park. I will have to check undernerath this weekend. Thanks.
Old Sep 7, 2007 | 05:21 PM
marton's Avatar
marton
I assume the auto box is full with fluid?
sudden failure sounds like TT or half shaft.
usually when TT fails then there is a lot of noise when you try to move forewards or backwards.
I think TT failure is relatively rare in S; relatively common in S4.
Marton
Old Sep 7, 2007 | 07:37 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Marton
The "won't roll in park" means the halfshafts are still intact, and the problem is forward of the parking pawl in the back of the transmission. The next test is the visual of the torque converter turning/not turning with the engine running. If the torque converter isn't spinning at engine speed, the torque tube/driveshaft has failed. After that, it looks more like a problem internal to the transmission.
Old Sep 9, 2007 | 02:20 AM
Darien's Avatar
Darien
Hey Henry,
Any updates
Old Sep 9, 2007 | 01:15 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
you might get lucky and find the flex plate has cracked at the flywheel, you can verify this after the quick test of starting the engine and viewing the bottom of the trans where the grill slits are if you see the torque converter spinning then you have problems in the trans. Since the car wont roll in park this means the CV joints are both connected as the trans will hold them in place
Old Apr 22, 2008 | 02:14 PM
hlj821's Avatar
hlj821
I finally decided to climb up under the car and take a look at it. I started it up and took a mirror and looked into the notch and could see rotation at engine speed. I cleaned the transmission fluid bottle and it looked full, so i opened the cap and about a half pint of fluid gushed out. This after only running the engine a couple of minutes. The fluid looked clean. Any advice on what to check next or what I might be in for? Thanks
Old Apr 22, 2008 | 02:27 PM
Nicole's Avatar
Nicole
Cottage Industry Sponsor
If a half shaft had come lose - as did on my car at very low speed - you would have heard loud banging of the shaft against anything in its vincity. In fact, you'd probably have severe damage to the rear suspension, if that had happened at 70mph.
Old Apr 22, 2008 | 09:23 PM
Darien's Avatar
Darien
Hey Henry,
I thought the Texas gang would've already got you back on the road
Keep this thread alive with updates and I'm sure you'll get the advice needed
Or, just fly me out for some tex mex and rita's and I'll get you squared away
Old Apr 22, 2008 | 09:58 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
What were you looking at in the "notch"? Was it the torque tube shaft? Look further back at the torque converter - the big round thing in front of the tranny. There is a grate in the bottom of the torque converter cover through which it is easy to see the converter spinning...or not.
Old Apr 22, 2008 | 10:04 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
When the engine is not running, the fluid level is way high, held in by the cap seal. Once the car is running, the fluid level should fall very quickly to the lower mark on the reservoir and gradually rise to just under the upper mark when it is warmed up. To me, what you observed is a sign that something that should be pumping the tranny fluid out of the pan is not doing so. Check whether the torque converter is spinning with the engine on.
Old Apr 23, 2008 | 11:53 AM
hlj821's Avatar
hlj821
Thanks for the advice, I will get back under the car of Friday. The saga continues......
