928 Forum 1978-1995
Sponsored by: 928 Specialists
Name that thingy- trivia question
Old 05-20-2003, 01:47 AM
4MIDLIF
4MIDLIF's Avatar
Post
Any opportunity to show off that engine...
Old 05-20-2003, 10:58 AM
Gregg K
Gregg K's Avatar
Post
That is very helpful guys. I dont' know what a thermo valve is, but that should be easy. I don't know what a WUR is either. (Remember, I've been driving a '55 chevy pickup for the last couple of decades. It's like an echo chamber in those engine compartments.
Wow. Randy, what an engine! I'm going to post that picture where I can look at it for inspiration. How on earth did you get that engine so beautiful? It must have stayed in your living room. Haha.
Old 05-20-2003, 11:03 AM
Gregg K
Gregg K's Avatar
Post
Randy,
Is that a thermistor on your radiator hose? Fan sensor?
Old 05-20-2003, 12:46 PM
Randy V
Randy V's Avatar
Post
WUR=Warm Up Regulator
Gregg, feel free to PM me.
Old 05-20-2003, 01:04 PM
Mark
Mark's Avatar
Post
DAMMIT RANDY -
STOP with that Pic already!!! It's just gonna cost me MORE time and money in the long run!
And - every time you post it - I have to replace my keyboard from all the drool!
<img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Old 05-20-2003, 04:53 PM
Sean79 5spd
Sean79 5spd's Avatar
Post
Richard & Greg, I confirm my 79 is plumbed the same way. And yes, this is a vacuumed controlled valve which release stored tank vapours from the carbon storage cannister under certain operating conditions. Same conditions under which the EGR valve operates.
FYI, i just replaced all those small hoses with new silicon hose (correct colors) from Hose Techniques. Very good product.
Sean
Old 05-20-2003, 06:53 PM
Cobey
Cobey's Avatar
Post
I looked, and found the little hose was disconnected at the valve, and trailed off under the spider. Not a whole lot of help, but at least I fixed something while I was there.
Old 05-20-2003, 07:03 PM
Gregg K
Gregg K's Avatar
Post
Yes. I ended up pulling the airbox to check the hoses. And found a weak waterline that eventually started pouring fluid all over the engine. Better now than while driving around. And I broke something else that was half cracked... So all in all, I got familiar with the car. I also have more questions now. Like is there supposed to be a wide open vacuum leak going to the blowoff switching valve? I'd ordinarily remove all of this crap, but this is a classic car and deserves to be just the way it was when new. Sort of. Meanwhile, you guys have been a super help. And now it's back to my timing belt tensioning.
Old 05-20-2003, 08:12 PM
Gregg K
Gregg K's Avatar
Smile
A quick check of the timing belt revealed an adjusting bolt that was almost falling out. The belt was flopping around. So I just tightened it to a sensable tension. I'm guessing it would pass the actual tension tool test, but won't know until the tool arrives. All in all a great day for this shark. It really helps having this forum to bounce off of.
Many thanks,
Old 05-21-2003, 01:36 AM
karl ruiter
karl ruiter's Avatar
Post
Be careful about tightening the belt without the tension gauge. I ran mine this way for a while figuring I could guess the tension pretty well and ended up with a broken cam. At the time it was not too hard to get one but I think they are getting rare.
Quick Reply: Name that thingy- trivia question
