928 Forum 1978-1995
Sponsored by: 928 Specialists
Hella H4 8" headlights
Old 03-20-2002 | 11:15 PM
Garry's Avatar
Garry
Post
I live in Canada and bought my set of Bosch 8" H4 headlights from UAP, United Auto Parts. FYI
Old 03-20-2002 | 11:28 PM
Moss928's Avatar
Moss928
Question
Garry, that's fine!. Where were you when I started this post? I am trying to be helpful! I want to be able to point board members towards a sure thing!
Old 03-20-2002 | 11:38 PM
Fletcher's Avatar
Fletcher
Post
I thought the bosch/hella h4's were 7". Isn't that the oem size on sealed beam unit?
Performance advertises these at $299ea wow you got a great deal!
I don't know what the diff between the bosch and hella are, anyone know?
Old 03-21-2002 | 01:38 AM
Dave H.'s Avatar
Dave H.
From: Seattle - it's not Hell, but you can see it from here!
Post
there are 7" H4's, used to run a set on a Rabbit i had. there are also 5" H3's, but they're just driving lights.
pat, you can get H4 bulbs *anywhere*...
Old 03-21-2002 | 06:56 AM
Moss928's Avatar
Moss928
Post
David, I have a question for you regarding the 8"/H4 swap on my 84. You mentioned that I already had the right bulb connector (I haven't looked/forget what it looks like).
Am I missing anything (other than the bulbs)? The H4's appear to have a pretty good size hole in the back for the bulb.
Does my connector fit right on/provide the proper insulation?
Old 03-21-2002 | 08:47 AM
Dave H.'s Avatar
Dave H.
Post
you can see from these pictures how big the base of an H4 is.
the bulb goes in the light (one way) and is held in with a spring clip. then a cap seals the bulb in and your wiring connects to the prongs. (been a while since i looked at them...)
Old 03-21-2002 | 10:35 AM
Moss928's Avatar
Moss928
Post
Thank's David. Does anyone know about Bosch's (OSRAM) H4 Cool Blue bulbs. I stumbled on them while researching bulbs. See link.
<a href="http://www.osram.co.za/news/press/2001/cool_blue2.html" target="_blank">http://www.osram.co.za/news/press/2001/cool_blue2.html</a>
Old 03-21-2002 | 03:13 PM
John V's Avatar
John V
Post
Patrick,
where did you end up egtting the lights and do they have more?
Old 03-21-2002 | 05:40 PM
Moss928's Avatar
Moss928
Thumbs up
To John V and all. I'm satisfied with the headlamps. The bulbs turned out to be seperate (which is good). This allowed me to research them (H4 Bulbs) and choose.
The following link helped me choose the bulbs:
<a href="http://www.roversnorth.com/wwwboard/messrr/47823.html" target="_blank">http://www.roversnorth.com/wwwboard/messrr/47823.html</a>
The following link is where I purchased the bulbs (Hella 78150):
<a href="http://www.rallylights.com/hella/xenon_bulbs.asp" target="_blank">http://www.rallylights.com/hella/xenon_bulbs.asp</a>
Here is where I bought the Bosch 8" H4 headlamps:
<a href="http://www.bowwow.ca/contact/headoffice.htm" target="_blank">http://www.bowwow.ca/contact/headoffice.htm</a>
I spoke with a guy named Jeff. The part # is 34-1305333904
Tel. 604-594-4300 (They are located in British Columbia)
They don't keep them as part of their stock, but they can get them. The whole thing took a week from start to finish.
Good luck!
Old 03-22-2002 | 01:07 AM
Dave H.'s Avatar
Dave H.
Post
these instructions might also help:
<a href="http://www.billsworkshop.com/P928S4/h5toh4/h5toh4.htm" target="_blank">http://www.billsworkshop.com/P928S4/h5toh4/h5toh4.htm</a>
Old 03-23-2002 | 10:26 AM
jpitman's Avatar
jpitman
Post
And now you can put in some REAL bulbs . Over here they sell 230/190W H4s, and double pole 30A relays. Not for road use of course. Just for cooking on. Hey, maybe thats why they park almost level?
JP Riyadh
Old 04-01-2002 | 11:10 AM
Moss928's Avatar
Moss928
Question
Did anyone (other than myself) pick up a pair? Mine look fantastic! They perform great and they really clean things up (regarding headlights and appearance)!
Old 09-02-2002 | 07:21 PM
BrianG's Avatar
BrianG
Post
So, where is "over here"??
Old 09-03-2002 | 01:27 AM
BrianG's Avatar
BrianG
Post
They sure look great on Patrick's car and I'd like to figure out where "JPitman" gets those HUGE lamps to run in them. Is ther anything else needed to install them into the headlight buckets of my US spec. 86.5 car?
Anyone else have trouble with this rfelated URL??
<a href="http://www.billsworkshop.com/P928S4/h5toh4/h5toh4.htm" target="_blank">http://www.billsworkshop.com/P928S4/h5toh4/h5toh4.htm</a> I just get a "can't find the URL" error msg.
Old 09-03-2002 | 05:14 AM
jpitman's Avatar
jpitman
Post
Sorry guys, I thought the location of Riyadh would tell you Saudi Arabia. The big wattage bulbs come with a small tang to stop them going ina std socket, but that snips off in a second. Anybody want a small Care package sent? I think they go for about $8 each. I am surprised you cant find them somewhere there. Just need to uprate the wiring, and/or fit some relays.
jp
Quick Reply: Hella H4 8" headlights
