928 Forum 1978-1995
Sponsored by: 928 Specialists
That O2 sensor.
Old Mar 8, 2003 | 03:17 AM
ViribusUnits's Avatar
ViribusUnits
Post That O2 sensor.
How fast should the O2 sensor react?
I was just looking at Theo's web site.
<a href="http://home.planet.nl/~Jennit/Technical/Technical.htm" target="_blank">http://home.planet.nl/~Jennit/Technical/Technical.htm</a>
Under the O2 sensor it says that the sensor should react with in a a second. If it takes 3-4 seconds to react to a pulled vacume line, then the sensor is too slow.
Is this correct?
Could this cause a wobbaly idle, dieing after a hard, full throtal acceleration followed by a quick stop, and other similer problems?
I know my sensor take more than 4 seconds to react to a major vacume line being pulled.
btw, thank you Brandan, I checked my pressure regulaters, and they are working well. The fuel rail pressure tests OK.
Old Mar 9, 2003 | 01:39 PM
ViribusUnits
Post
Well, if we don't know how fast the sensor should react, anyone know what the Bosch part # is for the universal sensor?
