Windshield moldings
Quick question for those who have replaced a windshield. Do you normally replace with new molding as well or use the old one? Are their any major problems using the old one? I need to get a new windshield and was wondering about the moldings as well. I don't have any leaks or wind noise from them now.
the windshield moldings are decorative only they do not seal do not even touch the windshield . The upper one must by removed carefully by prying against the old glass taking care not to bend it , the glass may crack but you are changing the windshield anyway . The Glass is glued into the body with sticky rubberised glue which stays sticky for ever . The rear hatch glass uses the same glue . If the upper trim is not damaged when removing it , it is used again .
I repainted mine while the installer replaced the windshield with a fast drying matt black paint. They look as good as new. I am actually missing one of the small side clips (that covers the gap between the top and side molding), I hope I can buy one somewhere.
regards,
Sab.
regards,
Sab.
<a href="http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic;f=14;t=004336" target="_blank">http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic;f=14;t=004336</a>
